Better take off
Scoop549
N.C.
Ranger xlt
91 3.0 straight drive he wants more bottom end power cheap, first vehicle
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
New gears are about the only thing that would make any difference but they are not cheap, especially if it's 4 wheel drive.
Scoop549
N.C.
Ranger xlt
8,372
Power to weight ratio
Add more power or reduce the weight
Yes, 4.10 rear axle will help alot and a Manual transmission
The 3.0l Vulcan was designed as a high RPMs engine
Most engines have best torque/power at 2,500-2,800rpm
3.0l Vulcan has that at 3,500-3,800rpm
So RPMs need to be HIGH right off the bat to get any power at all, its the DESIGN
You need to "drive it like a rented mule", doesn't hurt it, its what it was designed to do
If you drove around another engine and didn't go above 2,400rpm you would think it was under-powered for sure
Yet people drive around the 3.0l without going above 3,400rpm, and say its under-powered, DUH
Know your engine, read its specs
8thTon
--- Banned ---
806
Pennsylvania
My world is filled with stuff that needs to be fixed
Wow, I’ve yet to get my 3.0 off the ground!
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Add wings?
B-17 wings if you can get them, sturdy, good aerodynamics, hard to come be these days though.
fixizin
FoMoCo is forcing me to buy a 'yota
114
Ft. Lauderdale, FL
XL Spurt
3.0 (Flex)
A properly suspensioned Ranger can be safely airborne for up to 4 seconds at a time! =:O
Maybe convert to Flex-Fuel (heads + 'puter + $700 sensor + soft lines + ??...) and run E85?... been running straight E85 in my '99 V-VIN lately and yeah, she really torques-up above 3,800 RPM... gotta double-clutch to give the synchros a break... kinda hard to hear the stereo though... :cool:
ericbphoto
Overlander in development
16,627
Wellford, SC
3.0L
6"
The truck IS the stereo.
rusty ol ranger
2.9 Mafia-Don
7,578
Michigan
177 CID
fixizin
114
Ft. Lauderdale, FL
XL Spurt
3.0 (Flex)
Don't forget the top-turret, with twin .50s, to keep the F-150s from gittin' too uppity! :devilish:
Here's a drop-in model I found in the LMC catalog... your pursuing enemies will slip and fall on all the links and empty brass littering the ground...
45822
