Battery light on
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
The Battery light came on today. Everything seems normal. 91 3.0L 2wd auto. I checked the battery voltages:
key off - 12.65 vdc
key on/engine off - 11.94 vdc
key on/engine on - 14.65 vdc
I'm stuck and could use some help. It seems normal, is it possible that the alt connector is making a bad connection? or the battery light connection is bad? Belt is not loose or squealing.
I changed the oil yesterday and son drove it so I don't know if it did anything to the connectors on the alt. They do look normal.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Had the battery and alt tested at the local auto parts store. Both were good...
Checked the belt which was good and tight. Even tightened a little bit more. No changes.
How can I tell if the alternator has an external or internal regulator?
8,370
1991 Ranger
Look at alternator, if you see a 3 wire connector on the top/back it has internal regulator
The light green/red stripe wire on this 3 wire connector is the Battery Light wire
The way it works is that the Battery light bulb in the dash gets 12volts with Key on
The light green wire is the GROUND wire for the bulb
When key is on and alternator is off, the green wire is a Ground, so battery light is ON
When you start the engine the alternator should generate voltage, so green wire is no longer a Ground and battery light goes off
Unplug the 3 wire connector
Turn on the key
Battery light should NOT come on, because green wire is not grounded anymore
If battery light comes on then green wire has a short to a ground somewhere
If battery light is off then green wire is OK
Make sure Short white jumper wire on the 3 wire connector is plugged in, it plugs into a single spade terminal near the 3 wire connection on back of alternator
Plug 3 wire connector back in
Start engine
If battery light stays on then voltage regulator is most likely failing
The POINT of a voltage regulator is so you don't "cook" your battery or the electronics in a vehicle
The fact an alternator generates 14volts means the rotor part of alternator works, which is good, but not the whole story
Alternators needs to be restricted to under 15volts, and under 14volts after about 5 minutes of re-charging
And that's what the voltage regulator is there for, its a Limiter, a "regulator", lol
A 12v battery should be 12.3v to 12.8v, key off, under 12.3v means battery is failing
Your posted DROP from 12.6v to 11.9v with key on means there is an electrical issue, that's a BIG Drop with key on, maybe Fan was on HIGH, big audio AMP or auto headlights came on?
Anyway after start up test battery voltage, 14.6 was fine but REV engine to 2,000-2,500rpm and hold it there
See what voltage is, should be UNDER 15v
If it goes higher then regulator is bad and that's why battery light is on
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
@RonD Thank you. I will work on it tomorrow morning.
BTW, I did have the fan on med or hi. lol
  • ryan
    Forum Administrator
