lil_Blue_Ford
- Aug 6, 2007
- 6,189
- Butler, PA, USSA
- Ford
- Engine Size
- 4.9L
Who agrees?
Dihydrogen monoxide is colorless, odorless, tasteless, and can kill. Often the deaths are due to accidental inhalation of DHMO, but the dangers do not end there. Prolonged exposure to its solid form without protective gear can cause severe tissue damage. Symptoms of ingestion can include excessive sweating and urination, nausea, vomiting and body electrolyte imbalance.
For those who have become dependent on DHMO, withdrawal means certain death. DHMO also is responsible for accelerated rust and corrosion issues when in contact with metal objects. It is also responsible for billions of dollars in property damage each year.
The contamination is has reached every corner of the globe as it has even been found in the Arctic regions. The reason for this far reaching contamination is largely due to the fact that all major companies (and many minor ones) are using DHMO on a regular basis since it works well as an industrial solvent, coolant, fire retardant, for dispensing pesticides (once it is on food products, it is impossible to wash off), and more. Companies often dump the waste into local streams and lakes since the EPA has not regulated disposal of it yet.
Doesn't sound like a very good thing to me...
