Bad MPG. Is cat clogged?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Didn't they ditch the fuel pressure regulator in 1998 when switching to the returnless fuel system...
Uncle Gump
Token Old Guy
13,458
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I'm not exactly sure when they went returnless... but if there is no regulator on the rail... it is a returnless fuel system.
At 12MPG... something just doesn't seem right. No codes... no drivability issue... no fuel leaks...
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
clogged cat will smell like rotten eggs.
Pauls14
IL
I guess at the moment, I should check fuel and exhaust (cat and O2)
About plugs, coils, wires I don’t know. Engine works smooth, start good.
Pauls14
IL
Something smells after ride (around engine and exhaust (between cab and bed).
guys what do you think about EGR?
Roert42
4,961
Kintersville, PA
Ranger XLT
4.0 SOHC
I believe you would get a code if the egr was stuck. Although I don’t know that it would effect fuel economy anyway.
A little bit of EGR flow at idle will make it run rough. A little bit of stuck EGR valve will make it not start too.
Pauls14
IL
Mine engine works smooth. Ok, thank you
Pauls14
IL
Hi guys. Finally checked fuel pressure. On idle around 50-65 (was different pressure each time). But when I turn off, pressure down until 20 (during 15 minutes). Is it bad?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
No. Yes.
The pressure should hold for a pretty long time (like weeks).
BUT essentially every fuel pressure guage I've ever owned or used leaked just enough to make checking that impossible. So I'd be inclined to blame the guage for the pressure drop before blaming the truck...
If it's not the guage you could have a leaking injector, or leaking check valve in the pump.
Pauls14
IL
No. Yes.
BUT essentially every fuel pressure guage I've ever owned or used leaked just enough to make checking that impossible so I'd be inclined to blame the guage for the pressure drop before blaming the truck...
Maybe gauge from Harbor Freight is crap)
gw33gp
Ham Radio Operator
536
Costa Mesa, CA
4.0 SOHC
33"
That is not always true. A bad cat can smell like rotten eggs but a clogged cat will have little flow but may not have much smell to it. My main cat clog last year due to one of the front cats breaking up and all the material ended up in my main cat. There was no smell but there was no power because of the restricted exhaust. It would start up and idle normally, but as soon as I tried to rev it or drive, it would bog down.
