Pauls14
- Jan 14, 2021
- 0
- IL
- Ford Ranger
- Engine Type
- 4.0 V6
- 2WD / 4WD
- 4WD
I’ve bought the Ranger. 4.0 OHV AT 4WD 122000ml. My MPG around 12 (drive only on 2wd and not fast). Engine work smooth, idle is good, without rough. Temperature of water also good. I noticed only one issue. There is exhaust leak (between bed and cab), but after cat converter. When I pull over and turn off engine, smell like a burn dirty. I bought OBD scanner for 20$ in Walmart. Did not show codes. Is it clogged cat? What should I check? Thanks.
