Bad MPG. Is cat clogged?
Pauls14
IL
I’ve bought the Ranger. 4.0 OHV AT 4WD 122000ml. My MPG around 12 (drive only on 2wd and not fast). Engine work smooth, idle is good, without rough. Temperature of water also good. I noticed only one issue. There is exhaust leak (between bed and cab), but after cat converter. When I pull over and turn off engine, smell like a burn dirty. I bought OBD scanner for 20$ in Walmart. Did not show codes. Is it clogged cat? What should I check? Thanks.
Roert42
5,023
Kintersville, PA
Ranger XLT
4.0 SOHC
I would start with a basic tune up, plugs, wires, coils, air filter, fuel filter, oil ect.
A clogged cat could definitely be choking up the system, but I would start with the basics first.
MikeG
752
central Texas
B4000
2"
235/75r15
That's pretty terrible mileage. I just thought mine was bad, till I read that....
I did pick up a couple MPG with a product called 'cata-clean' that I found at the Zone. Whether or not that would help you, I don't know for sure.
Lots of things could screw with your mileage, though.
Pauls14
IL
Previous owner changed plugs, wires and coils. Also engine works good, without misfire.
Roert42
5,023
Kintersville, PA
Ranger XLT
4.0 SOHC
What size tires are on it? someone could have put larger tires on it before you got it, and never regeared the diffs.
Pauls14
IL
265/75/15
Pauls14
IL
What do you think about check intake pressure? I watched YouTube, guys check clogged cat.
The gauges is 20$ on Amazon. Only I don’t know what hole use in Engine.
sheep herder
1,024
sheep pen
If it ain't broke, break it.
265/75/15
Has your speedometer/odometer been corrected? If not, you're not even getting a correct mileage reading which makes calculating mpg impossible.
Roert42
5,023
Kintersville, PA
Ranger XLT
4.0 SOHC
Check the sticker on your driver side door jam, should tell you what size it came with originally. Sounds a little big.
I am also not familiar with that process.
Pauls14
IL
Yes, is correct. I checked on highway and google maps.
Pauls14
IL
I’be checked. Same size.
gw33gp
Ham Radio Operator
538
Costa Mesa, CA
4.0 SOHC
33"
I had a clogged cat and gas mileage was not a problem. I just could not get up to speed very fast due to less power. It would idle fine but would not rev up very far.
Pauls14
IL
I have not problem with rev up. Engine work very good, no check engine, but mpg(((
ford4wd08
513
Alcoa, TN
2.8 V6
Usually a clogged cat gets very hot. Has been known to melt the carpet in the cab.
Pauls14
IL
What should be temperature outside cat? Will be check tomorrow
