Woogie
- Sep 23, 2013
- 15
- Boise, ID
- Mazda
- Engine Size
- 2.3
I have a 1995 B2300 with a cassette deck and a manual trans. What idiot at Ford thought right behind the gear shift knob was the perfect spot to stick the cigarette lighter? Every time I shift in or out of first I run the risk of busting my knuckles on the power adapter for my phone or catching the cord and pulling it out.
I'll be pulling the instrument panel to replace some of the backlight bulbs, so I've decided to swap out the factory head unit with an aftermarket deck that has a USB port. I can charge my phone off the port when it needs it, and use Bluetooth when it doesn't. The stock head unit has an auto set button, and I'm told that means it has the factory amp. I don't care about the amp one way or the other.
This is the deck I'll be using:
http://www.pioneerelectronics.com/PUSA/Car/CD-Receivers/FH-X700BT
Is this the correct connector?
http://www.scosche.com/car-audio/installation/88-97-fd-ma-prem-connect
Just want to make sure I'm ordering the right part! It sucks when you get everything dismantled and find out you don't have what you need.
