Alternator wiring
dieselarruda
2.9L6V
Hello
Replaced alternator on 1988 ford ranger truck 2.9L
what is the wiring order? I did not label wires for re installation
3 wires
Green with red stripe
white with black stripe
yellow with white stipe
dieselarruda
2.9L6V
Hello
3 wires
And the other cable with two black with orange stripe and yellow with white stipe
PGHFord
Pittsburgh, PA
2.9L EFI
freedom5
San Antonio, Texas
2.9
Hello
3 wires
Green with Red to terminal "S"
Yellow with White to terminal "A"
freedom5
San Antonio, Texas
2.9
The info I submitted above was from my Haynes manual. I went out and looked at the connections on my 1987 Ranger 2.9 and both cables connect with a push on connector so I can't verify the color codes.
My apologies - don't want you to fry the new altenator.
dieselarruda
2.9L6V
Their are six wires, are they all needed for the alternator?
PGHFord
Pittsburgh, PA
2.9L EFI
3 go to the main(larger) alternator plug and 3 go to the voltage regulator plug the smaller one.
dieselarruda
2.9L6V
lodden758
coopersville, MI
2.9
what is that alt off of?
dieselarruda
2.9L6V
what do u mean?
dieselarruda
2.9L6V
rewiring my alternator
here is the a video http://www.youtube.com/watch?v=RzUq2pykmHs&feature=plcp
i think i wired it wrong because the green wire on the solenoid started to smoke so let me know what wires to hook it up right.
and when i put the positive and negative on the battery they throw sparks and i guess its wired wrong
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
X2. That alternator is not factory. Do you have a diagram of what each post says? I would also recommend using connectors rather than wrapping the wire around the post.
kunar
131
Toledo, Ohio
5.8l
how many times/places are you going to post about your alternator? put the post in the proper forum and im sure if somebody knows something they will be glad to help. no reason to cross post.
