2.3L ('83-'97) Adding mechanical oil pressure gauge
rosscob
33
Oregon Coast
Ford Ranger XLT
I've got an '88 XLT with a 2.3, 5 speed manual that just has an idiot light and I want to add a mechanical oil pressure gauge. From what I've read the original sending unit is located on the drivers side near the back of the head. There's so much crap on this engine that I can't even see it. Is there any other place on the motor where I can tap in to get a gauge working?
ericbphoto
Overlander in development
TRS 25th Anniversary
16,767
Wellford, SC
3.0L
6"
I believe it is possible to add an adaptor between the oil filter and the engine block that would provide ports for oil pressure sensing and also for remote oil cooler.
scotts90ranger
4,509
Dayton Oregon
2.3 Turbo
It's right here, get yourself a "street tee" in 1/8" NPT (literally what it's called, male threads on one end and two female threads). It's kinda tight in the rig but doable, I've messed with the one in my '90, booster is right where you want your arms, or you could do it from the bottom just harder... The oil and coolant senders are shown in this picture, oil is the upper one.
rosscob
33
Oregon Coast
Ford Ranger XLT
Thanks. I looked earlier today and I know where it's supposed to be, I can't even see it. I've seen what they call a "sandwich" adapter, I think that's what ericbphoto is referring to. They're $25 or so but it looks a lot easier that trying to get to the stock sending unit.
4.0blue98
I don't feel tardy...
705
Frederick, Maryland
4.0 OHV
Round
It was like that when I found it.
These sandwich adapters are pretty good. Just make sure you still have clearance to get the filter on and off. I'm not a big fan of using a shorter, lower capacity filter in this case.
8,374
You access the oil sender from under the Ranger same as oil filter
rosscob
33
Oregon Coast
Ford Ranger XLT
I'll take a look at it tomorrow. Just spent 4 hours mowing my lawn so I'm done for the day. Thanks.
scotts90ranger
4,509
Dayton Oregon
2.3 Turbo
You must have one of the intakes with the 4 runners inline instead of a square... come to think of it on my '97 I'm not sure you could see it from the top... would be doable from the bottom but tight...
