AC cuts off when accelerating
Lemarque
5
New Mexico
Ford Ranger FX4
Searched but didn't find anything that described the following:
Cruising, the AC works fine. Under even slight acceleration the fan stops; that is no forced air from the vents. Backing off the gas, the fan starts blowing again with cold air. Driving country roads with even gradual uphill stretches is a real pain in NM when the AC (fan) stops. So I'm guessing that somehow the fan is in some circuit with the AC?; but I'm only guessing.
Any help appreciated.
2008 FX4
rusty ol ranger
2.9 Mafia-Don
7,569
Michigan
177 CID
You sure its stopping or is it switching to the defrost vent?
I had an Econoline that would do that and it would blow out the defrost. It was a vacuum issue somewhere...never figured out where.
Alan_nc
140
US
Ranger Splash
Isn't the AC supposed to shut off under acceleration? Sounds like yours is a bit sensitive. Just for comparison does the fan shut off when you have the heat on and accelerate?
Lemarque
5
New Mexico
Ford Ranger FX4
Thanks guys.
Driving this morning with just the fan on (no AC) it behaved the same. No fan under acceleration.
Scheduled Monday for some minor work with my mechanic and I'll ask him to troubleshoot for a vacuum leak unless someone relies with additional info.
8,372
You are loosing vacuum in the cab when accelerating, common issue
In the engine bay there will be a grey and a black hard plastic vacuum lines coming out of firewall on passenger side
Black one is the main line and runs forward to the Vacuum reservoir in the lower front of engine bay
This black line cracks or is melted by exhaust
Lemarque
5
New Mexico
Ford Ranger FX4
Thanks RonD - Probably saved me a good bit of cash in troubleshooting.
Not the best pic, but I'm really enjoying my second Ford. First was a 57 Ranchero I bought at auction 30 years ago.
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
I drove an E-350 with the same issues. It was a work van, so nothing ever got fixed on that beast.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
As Ron said, vacuum issue. Same problem with my truck but was a broken check valve. Engines don't make vacuum under acceleration and vacuum is what holds the vent controls in position so if you loose vacuum it switches to defrost. (Default mode spring operated). The vacuum reservoir stores vacuum so you don't loose control of the vent position, but with a leak or bad check valve, it magically disappears when you hit the gas.
Uncle Gump
Token Old Guy
13,489
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I will say however... a vacuum leak is one thing causing the air to not blow out the right place... if the fan completely stops working... that is an entirely separate issue. The fan should continue to blow...
gw33gp
538
Costa Mesa, CA
4.0 SOHC
33"
I agree with Dirtman. It seems like the fan shuts off but the air is just directed to the defrost vents as a default and it just seems like the fan shuts off. I had to replace my vacuum reservoir because the check valve went bad. It was a pretty easy fix on my 02. I suspect an 08 would be similar.
Lemarque
5
New Mexico
Ford Ranger FX4
<thud> The fan stops completely. So what would cause this?
Lemarque
5
New Mexico
Ford Ranger FX4
Doesn't seem to be coming from the defrost vents. Fan stops completely.
Uncle Gump
Token Old Guy
13,489
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I'm not sure where you would go from there...
Are you positive it doesn't just switch the coming out of the defroster?
Lemarque
5
New Mexico
Ford Ranger FX4
I'll double check tomorrow but I reached over to the windshield this morning and didn't feel anything.
