wgb
- Feb 23, 2018
- 0
- Ford
I have a '95 Ranger XLT and wanting a tach, I installed a later model gauge cluster which has the tach. It look like most of the gauges work, but there are a few things I'm not sure of.
1.The tach looks to be reading half rpm; the engine seems to top out about 3500 rpm per the tach, but HP output is rated a 4200 rpm. Is there a fix for getting the true rpm reading on the tach?
2. When the door is open the "Fuel Reset" light comes on. I don't know what fuel reset means, but do I need to switch some wires to get the Door Ajar light to come on?
3. The temperature gauge seems to read high - when warmed up it is usually near the top of the gauge. I have not used a thermometer to see what the temp really is, but I'm wandering if it is showing double the actual temp (similar to the tach reading half the actual rpm)?
I don't know the year or trim level of the Ranger (or maybe Explorer?) I got the gauge cluster out of (I pulled it at a U-Pick-It yard) several years ago.
Any help or suggestions would be great. I can live with it as it is, but would like to fix it if possible.
