back from the pick an pull. Found a 96 3.0 5 speed transmission. The 96 has the 3 part transmission cross member with the rubber bushings on each end.
Managed to get the clutch/brake pedal assy. shifter boot and shifter cup holder ,and 5 speed trans tunnel plate out of a 92 and the clutch safety switch. Got the harness dropping down to the O2 sensors,VSS, reverse lights on transmission,got 2 speedometer gear assy, and the PRND black plate. Did not get the column as it did not have tilt,cruise but did get the shroud to see if it will cover the auto column after removing shift lever.
Will be going back in couple days to pull driveshaft out of a 92 5 speed super cab,it had a 2.3 motor that was gone and pull the trans. cross member out of the 96. Got to take my drill and cold chiesel and hammer to get the rivets out of frame.
All in all a good day cost so far 40$
