93 explorer 4x4 not working after replacing radio
methmonster420
I've got a 93 explorer 4liter I just replaced the radio and now my 4 wheel drive is not working ive checked fuses and they are all good any suggestions its got the push button auto 4x4
3,615
Did you unplug the switch at all while playing in the dash?
methmonster420
No i didnt unplug the switch the 4x4 high button lights up but the 4x4 low button doesnt also the light doesnt go off it just stays on when i press it on and off and the 4x4 high light is very faint can hardly notice its lit up
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
Pull it back apart and make sure it is plugged in all the way.
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS 25th Anniversary
8,858
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
You didn't mess with the 4wd module did you? I think some people think those things are amplifiers or something. They're behind the rear panels on the drivers side.
methmonster420
No but i did cut the wires to the old radio and spliced the connections into the new radio is the module tied into the radio i checked all the connections and everything is hooked up and in the right place maybe its just a coincidence the 4x4 went out when i replaced the radio is there anything else that could cause this and things i could check
dankhimself
Northern NJ.
Did you cut the factory connector off or use an adapter harness for aftermarket head units? It seems as though you might have damaged the wiring to that 4x4 switch, either by cutting something by accident or pulling and pushing the harness in and out of the dash. I know my harness is kind of a pain with head unit clearance when installed so I had to kind of shove the harness deeper into the dash to get it all to fit while installed without having a ton of pressure on the back of the radio. It even popped out of the dash board while driving once!
