93 1354e parts?
93 4x4
florida
Went to a 1354m awhile back best thing I could have ever done but I still have the 1354e sitting around tried of looking at it is there any good internal parts to keep for the '91' 1354m off of it before I send it to the scrap yard?
FritzTKatt
4
Ohio
AFAIK a 1354 is a 1354... the only difference is the way you control it. So all the internals should be the same.
Just wondering, can you shift into 4hi from 2hi while moving with a manual? Since the electric is the same thing and will do it.
93 4x4
florida
Yes it will shift no problem. Thanks for the reply
snoranger
Professional money waster
ASE Certified Tech
13,729
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Most of the internals should be the same. If both have the same low range planetary gear sets... early 13-54s had 4 gear, later ones had 6 gear. The 6 gear uses a different front plate, gear set, shift hub, and shift fork. The are interchangeable, but all the parts I listed have to be swapped together.
The main shaft, chain, outputs, etc are all the same until you get into the later years with the front CV output.
If you have a place to store it, keep it for spare parts.
