i would run a bottle of injector cleaner through it... a poor spray pattern could leave you with unburnt fuel... even though you're not technically running rich, there could be unburnt fuel exiting the cylinder, which is exactly what HC is... i would dump a full bottle of some super strong injector cleaner in, and do it with minimal fuel in your tank, and run the crap out of the motor until you are virtually dry, then top it up with 87 octane... (yes i know everyone recommends 91+ octane for smog testing)
the higher the octane rating, the longer it takes for the fuel to burn, which means you have a greater chance of unburnt fuel exiting the cylinder... low octane fuel burns fast and aggressive, though it has no more actual energy than high octane fuel does... the other thing that may help is low octane fuel tends to have more ethenol in it, and if i'm not mistaken, ethanol is NOT a HC string, which in theory, means that if you get 201.2ppm HC, with straight fuel, and then switch to e10 ethanol (10% ethanol) your fuel going in is only 90% HC, which will effectively lower your reading to 181.08ppm... the other thing you can do, now i make no claims as to if this will work or harm/not harm your truck... but you can put methyl hydrate in your tank, it is sold at gas stations as a water remover, usually a little 6oz bottle for 7 bucks... don't bother with that... go get a gallon from a hardware store's paint department, usually around 12$... dump that into the tank, it again, not HC string, so literally lowers your HC reading right there also!
i was recommended about 1/4 gallon of methyl hydrate for 5 gallons of fuel or something like that... i dumped in 1 gallon for about 3 gallons of fuel... my 88 tempest ran just fine, absolutely no effect on driveability, and no CEL either...
again, i take NO responsibility if something happens... do so at your own risk, i did not have any issues doing it in my vehicle, but that does not mean you will have the same results
though i usually lean towards a bad o2 sensor when i have rich/lean issues, never personally had a bad o2 (out of the box) though... so hard to say...
