91 4.0 Wiring
rob864_0
4
Pasco, WA
Ford BroncoII
Doing a swap, my donor is a 4.0 w/auto from an Explorer. Wiring diagram shows circuit 37 #10 Yellow. Where the #37 pin on Firewall connector is a #10 with light green insulation. Can I assume the pins and wire size are correct and the insulation is off?
Thanks in advance for your help.
rob864_0
4
Pasco, WA
Ford BroncoII
Was planning on using that for my power to underdash fuse block.
Thanks, rob
jtaborsky
7
Bismarck ND
4.0L OHV
4"
32's
Break. Upgrade. Repeat.
What are you swapping it into? I can check later if I remember. My swap was '92 Explorer engine into an '87 Bronco II.
