91 4.0 Wiring
rob864_0
4
Pasco, WA
Ford BroncoII
Doing a swap, my donor is a 4.0 w/auto from an Explorer. Wiring diagram shows circuit 37 #10 Yellow. Where the #37 pin on Firewall connector is a #10 with light green insulation. Can I assume the pins and wire size are correct and the insulation is off?
Thanks in advance for your help.
Rock Auto 5% Discount Code: F9A1A579ACFAD1: October 1st, 2021
rob864_0
4
Pasco, WA
Ford BroncoII
Was planning on using that for my power to underdash fuse block.
Thanks, rob
jtaborsky
Bismarck ND
4.0L OHV
4"
32's
Break. Upgrade. Repeat.
What are you swapping it into? I can check later if I remember. My swap was '92 Explorer engine into an '87 Bronco II.
