firehawk618
- Aug 10, 2016
- 0
- Ford
- Engine Size
- 2.9
I'm putting this in the general forum since I have a few questions in multiple categories and figured it would be best to keep it all in one post. Forgive me if this is the wrong way to look at it.
Hello all. I have been lurking here a while but haven't posted much because up until now I really have found everything I needed on these forums.
I have a clean 1989 Ranger Extended cab, 2.9L 4x4 with the FM146 transmission.
The engine, trans and transfer case work perfectly but I picked up a complete 1996 Ranger 4x4, extended cab, 4.0 with 5 speed and push button 4wd that's got a solid drive train but the whole body is garbage.
I will be swapping in the 4.0 first. I know the wiring is as far away as the 2.9 as I could have gotten but I have the truck so I will be making it work.
I will be swapping in the whole 1996 OBDii setup. Call me crazy but I want obdii instead of EECiv. I'm not worried about the wiring as that is my specialty.
One question I cannot find the answer for is will my existing transfer case linkage work with the M5OD or will I be forced to find manual transfer case linkage from another M5OD?
I will be getting the engine conversion done first so I am not in a huge rush for a solid answer on this but will want to get the parts lined up so when I am ready for the transmission swap I will have all parts needed.
The M5OD is noisy in all gears except 4th so I will tear it apart and put all new bearings in it and I am assuming it's going to also need an input + main shaft. Once I get it opened up I will order any parts that are needed.
So other than the question with the manual transfer case linkage FM146 to M5OD and the complicated wiring work that will need to be done does anyone see any gotchas I should be aware of?
Thanks for any input in advance. I will post pics of both trucks soon.
