'88 Nissan "850" D21 HardBody
Ranger850
Doesn't get Sarcasm . . .
4,699
Tallahassee Florida
Stock 2"
Stock
Replaced the single piston calipers with the V6 dual piston calipers and bigger rotors.
59918
59919
I did change the hoses too, and was a little concerned about how the sat, but no worries, after a test drive they did not rub the tires. I also repacked the bearings with new grease, the stuff that was in there looked like old motor oil. I also cleaned and painted the brake dust covers. When I took them off to trim for the bigger brackets, I stripped out one of the aluminum screws used to hold it on, one each side lol, and had to drill off the screw head, but left the shaft as a little holding stud. I dabbed some hi-temp gasket maker on the stud to keep it from vibrating in the future, we'll see how that works. After bleeding the brakes, I took it for a test drive, and it stops,
Ranger850
4,699
Tallahassee Florida
Stock 2"
Stock
Didn't do the tie rod ends, waiting to get more parts. BUT, I did take out the explorer console that was in there and put in an actual Nissan console. It came out of a much newer truck and the rear bracket is supposed to attach to a small airbag computer that I do not have. So i had to fab up a bracket.
I started with a 4" piece of 2x3 aluminum angle
59920
And two 5" pieces of 1" aluminum square tube
59921
59922
Finished the home made bracket
And... Wha La
59923
Ranger850
4,699
Tallahassee Florida
Stock 2"
Stock
My Mirrors have always been a weak spot of the truck. The PS mirror had a huge round, convex, bubble type of thing bolted to it, and the DS mirror always tilted down when I shut the door.
59950
Not sure what year it was, I forgot to look. But what I did notice, was that the Xterra mirrors looked like they would fit my D21.
So I snatched one off the Xterra, and dry fit it to the HB in the yard, and WHA-LA, a match.
59951
I dry fit them on my HB, and instantly noticed I had some cutting to do.
59952
59953
After everything had been mocked up and fit well, It was time for some protection on the fresh cuts, so a quick tape up, some sanding and primer before a shot of Gloss Black, Thankfully the mirrors covered up most of my work. lol
Just for comparisons sake. The Xterra mirrors are definitely beefier
59954
59955
Ranger850
4,699
Tallahassee Florida
Stock 2"
Stock
Well, With some extra time, I thought I would clean the engine up some more. I decided to remove a connection for hoses that I had previously just plugged, and make a plate from galvanized sheet metal. All thing were going well until I cross threaded a bolt and it snapped when I tried to back it out. FML
59957
My plan was to seal the hole with a bead of gasket maker around it. So that's what I did. But with the broken bolt in the hole, I couldn't get a good tight seal. I didn't want any air seepages, so I sealed the edges of the plate too. I decided to paint my bracket white while I had it off. IDK why, but I like it.
59958
Originally, each bolt on the right had a ground attached, so I just move the top on to the bottom. I hope that wont cause problems down the road.
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS 25th Anniversary
8,815
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
My very first vehicle was a Datsun pickup my dad gave me back in the 80's. Fun little truck.
Ranger850
4,699
Tallahassee Florida
Stock 2"
Stock
This is my 2nd Nissan. I had a 720 (datsun pickup) for a few years in the 90's. Back when I was in to minitruckin'
Ranger850
4,699
Tallahassee Florida
Stock 2"
Stock
59973
This is what years of vice grips for window cranks looks like.
So I replaced them
59974
Now I can use these
59975
Jim Oaks
Administrator
Supporting Vendor
8,815
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
My Datsun looked like this, red with the ST stripes, but it was 2WD.
I actually looked for a Datsun 4x4 back in the early 90's, but couldn't find one. I eventually ended up with a Ranger.
Ranger850
4,699
Tallahassee Florida
Stock 2"
Stock
I cant see a pic, if you posted one.
Definitely a 720 if it was an "ST" Should have the smooth bed without the hooks too.
Jim Oaks
Administrator
Supporting Vendor
8,815
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Fixed it.
Ranger850
4,699
Tallahassee Florida
Stock 2"
Stock
@dvdswan may know more than I do, but I thought the ST trucks had the smooth bed sides with "no hooks"
Ranger850
4,699
Tallahassee Florida
Stock 2"
Stock
mine looked like this, but had wide chrome rims and was lowered. Blue interior.
60519
89Twincharge
182
Nice build keep it it in the family
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
1980-1984 had the hooks on the side. 85-86 had smooth sides. 83 I think was the 1st year to have "Nissan" in big letters on the tailgate.
ST was just a package just like STX is to Ranger.
60549
60550
This was mine. Ignore the 80s hair style.
Ranger850
4,699
Tallahassee Florida
Stock 2"
Stock
60808
Went from this
60809
To this
