88 EXT cab ranger v8 swap pics
kamshaft
appleton wi
347
so last night i decided to scrap the ladder bar setup because there was no articulation of the back axle and i thought i might wreck something if i pull into a big enough driveway... sooooooo here is the outcome of all-nighter
kamshaft
appleton wi
347
and my steeda tri-ax came
kamshaft
appleton wi
347
so here is a couple more pics of the 4 link and motor updates running stand!! custom ford motor plate that i made for my engine guy so he can run fords on his stand
kamshaft
appleton wi
347
well as of right now motor and trans are all in and fuel lines and brake lines are in and done brakes have been bled hand brake is awesome kwik wire harness is being installed as of right now.
here is the steering shaft now all done no extra heims or u joints i movet the collumn over an inch towards the driver sice where it comes through the firewall
kamshaft
appleton wi
347
continued progress....
custom air cleaner spacer to clear the hei distributor
5 inch aluminum driveshaft shortened by me with 1330 to 1310 u jounts "chevy to ford"
kamshaft
appleton wi
347
custom coil over shocks!!
brakes painted and back on the truck
kamshaft
appleton wi
347
brake lines done and bled also box is on the truck with the roll pan and some pics next to my buddies SD
custom bracket for under dash adjustable proportioning valve
kamshaft
appleton wi
347
So what all is involved in moving the steering column over? And how much clearance do you think it gained you? Awesome build by the way.
here are some pics
ang here is a pic of where the steeringshaft was before and i actually would have had to notch the header about a quater of an inch and it still would have been less then an eighth inch away and that was the smaller inside shaft if you look way to the right you can cee the rubber bushing just barely in the picture
doorgunner
Lab Rat for V.A. hospital
MTOTM Winner
2009 Truck of The Year
516
New Orleans (8' below sea level & sinking)
350+1
N/A
3/4
23570R15
JESUS Loves Ya!
That Injun sounds/looks good....test stand looks good :yahoo:
doorgunner
MTOTM Winner
516
350+1
N/A
3/4
23570R15
JESUS Loves Ya!
:yahoo: You went & snuck a buch of new pics into the thread while I was commenting on the older pics.....
everythang looks G R E A T !!!
kamshaft
appleton wi
347
:icon_rofl:
Thanks and yea i have a build thread on rps and i wanted one on here too
slingshot
Damn Kam! Don't know what your long term careeer plans are--but if you did all this welding and fabrication, you should definitely look into working in a NASCAR team shop or top end street rod builder. You got skills! BTW--suspension parts are all boxed up and ready to ship...
