86 f350
NMB2
July 2010 OTOTM Winner
22
Cody, WY
5.0 V8
So I posted this thing up awhile back when i first go it.. paid $600 for it and drove it home. Ive been working non-stop on it for about the last week and I've gotten some decent progress on it so far. I am about $2800 into it now with all the parts I bought, although it still looks like hell, most of the mechanical is coming to an end and then I can start on cosmetics.
Parts:
I tore the motor down to the block, cleaned everything.... That took nearly 2 days to do by myself. Finally ended up getting heads back on. I'm using the Fel-pro gaskets and ARP studs, over torqued 15lbs.
Also used Fel-pro manifold gasket and everything else. You can see the extra drain holes i punched in it.
Replaced the 6.9 pump with a 7.3 pump. I'm also using "B" code injectors. Got the fuel system reassembled.
VDO water temp sender
Trans in
engine as of tonight:
NMB2
22
Cody, WY
5.0 V8
got some more work done today. Stripped the interior. Turns out there is a bit more rust in the rockers than I first thought, but I will still be able to patch them up no problem. The main parts of the floor are solid.
Got the clutch pedal assembly in... the hole I cut and mounted the master cyl in is too low so that sucks, I will have to move it tomorrow. Got the accessories back onto the motor minus the alternator which needs to be replaced, and the A/C compressor which I will put back on when I get all new A/C parts.
Dangeranger3
Peoria, IL
420
Very nice. I just picked up an '87 about a month ago. I'm not running any boost though. The IDI's just run forever.
NMB2
22
Cody, WY
5.0 V8
so I have come to the realization that 1 of 2 things will happen. Either this truck will eventually get a cab swap, or its parts will go into a good rolling chassis. The cab rust in the rockers turned out to be pretty bad.
Now, I am by no means good at body work, but I think that this will hold the truck over for quite some time.
Will
514
Gnaw Bone, Indiana
Toyota
Yeah, so many old trucks that I see as good deals have these secret problems. At least that motor has a turbo. I'm assuming it is a tow vehicle and there is nothing worse that a nastily asspirated diesel as a tow vehicle.
I bought my '88 in Florida 6 years ago almost exactly with 46,000 on it and the body was like new. I'm just this year starting to see rust in the usual places. I bought this for practical reasons knowing it would eventually succumb to the midwestern rust, but now I see it as a classic that I should take care of. I need to sell it and get a newer truck, but I doubt I will. It serves my purposes too well. I think it will rust out from underneath me in 20 years.
NMB2
22
Cody, WY
5.0 V8
ok so although ATS has quit building parts for these trucks, hypermax and Banks still do, and Banks makes a downpipe to fit the ATS kit. I ordered the downpipe Wednesday, paid for 2nd day air and came out to $149.95. Received that pipe friday, but I was on EOC 24hr duty so I couldnt do anything with it. The issue with the stock exhaust housing is that its only 2.25" at the outlet. Pointless to put a 3" downpipe on and still have a 2.25" outlet on the exhaust housing.
NMB2
22
Cody, WY
5.0 V8
NMB2
22
Cody, WY
5.0 V8
thanks. Ya its coming together. now that all of the mechanical is pretty much finished, I can start on wiring all of my gauges and putting interior back together.
NMB2
22
Cody, WY
5.0 V8
almost done... just have to finish interior.
RUTH
September 2010 OTOTM
lookin good...really liken the dash
