'84 radiator mounting
88mudder
waterford michigan
How does the radiator mount to the core support on a 84 Ranger? Replacing my radiator. Any pics? Will i need to fabricate brackets? -thanks-
88mudder
waterford michigan
who has an 84 ranger that can tell me how it mounts..?
Mudhound
Eaastern Ky- out in the woods ( literally)
87
173 and 331 CI
I have an 84 BII, and the radiator was bolted in at the top on each corner, and simply sat on the brackets on the bottom. really simple, I thought. I also swapped out my original rad lthat was leaking for one from a 91 "X" that was a 5spd, Ranger would be the same of course, to make it easier to find in a junkyard. I ended up having to drill the holes for the upper mounts, and trim off the little "pegs" on the bottom of the tank to get it to set right, but would would swear that it is a factory one core Alu. rad. sitting there. The 4.0 fan shroud also fit perfectly. I can get some pics. tomorrow if you would like.
88mudder
waterford michigan
cool thanks, pics would be good
