64" swap question
grey
Hamilton, Ont
sooo...
I started on a 64 swap(with shackle flip), but once I had the spring in on the one side it didn't seem quite right.
I moved the front bracket up so it matched with the front holes on the frame, then drilled 2 holes where there were none.
In the air....
but when its loaded up with just the weight of the frame, it looks as if the shacke sits way too far back....
So my question is, when you use 64's do you move the rear shackle back as well?
Boggin
48
im thinking you should of had the front bracket forwards more. i heard that on the extended cab models you need to cut out a section of the rear body mount
Andres629
11
Saskatchewan!
2.9 screamer
I moved the rear hanger back 3" on mine. Your front hanger looks different as well, I'd measure to see if it moved forward the 6" it was supposed to.
grey
Hamilton, Ont
hmmmm....
the rear cab mount on my truck is wayyy under there... I'd say about 6" behind the rear wall of the cab. I could probably move that bracket forward another 2 inches or so without having to put it on a weird angle, or before I start to move my axle forward with it.
Boggin
48
just out of curiosity are you using stock shackles? how much lift are you getting
grey
Hamilton, Ont
The hole centers are approx 6.25" apart, so if anything my bracket moved forward more by about a quarter inch. I guess I have to move my rear bracket back more... but the hitch is in the way :dunno:
grey
Hamilton, Ont
Yeah they're stock for now....
I removed the factory lift blocks, which were only an inch thick.
I havent measured exactly where I am now, but after flipping the shackles and putting in the 64's... it looks like im sitting at the stock height... without blocks
hondarider94
Nevermind i got confused with the 6400 shackles
