grey
- Dec 4, 2009
- 0
- Hamilton, Ont
- Ford
- Engine Size
- 4.0
sooo...
I started on a 64 swap(with shackle flip), but once I had the spring in on the one side it didn't seem quite right.
I moved the front bracket up so it matched with the front holes on the frame, then drilled 2 holes where there were none.
In the air....
but when its loaded up with just the weight of the frame, it looks as if the shacke sits way too far back....
So my question is, when you use 64's do you move the rear shackle back as well?
In the air....
