5 Speed Manual Transmission trouble
kdowney50
2.3L SOHC
I have a 1994 B2300 w/5 Speed manual transmission. Its going south fast. Anyone here ever rebuilt one? I found a kit on line for $275.00. Otherwise a used one is $350.00 and a complete rebuild is $650.00.
I am an industrial mechanic by trade. I have tools and access to a hydraulic press. However, I have never rebuilt a manual transmission. What am I getting myself into?
I don't want to buy a used tranny and pay for some one else's problems. However, having it rebuilt is out of my price range right now. So, unless you guys talk me out of it, I'm going to rebuild it myself!
Let me know what you think.
mp3deviant721
24
Eau Claire, WI
2.3l of fury
I haven't rebuilt one myself but, I've heard that you need to take apart the transmission to find out how many teeth you have on the 5th/Reverse slider (I assume what the company meant was synchro sleeve, IDK). And there is a cheaper rebuild kit on ebay. It goes for $179.45.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=220574539441&viewitem=&sspagename=STRK:MEWAX:IT#ht_1204wt_941
If it were me though, I'd just get a reman unit. It's easier that way. But if you want the challenge, then I say go for it and rebuild your current transmission.
3,614
I have rebuilt these transmissions. They are pretty simple units. If you are an industrial mechanic then you probably have the required skills to do this. You do need to figure out how many teeth are on the 5th/reverse SLIDER to get the right kit though.
This is a sliding reverse gear transmission. If you decide to do it yourself PM me and I'll copy the instructions from the Ford shop manual for you.
kdowney50
2.3L SOHC
Mucahs Gracias!
Thanks for the support and info! I can save money and do the rebuild with instructions! What could be better?
3,614
I'll have to pull my old computer out and find the copy of the instructions. I'll do that tomorrow and send them to you then.
kdowney50
2.3L SOHC
Tranny Trouble Redux
OK, I got the tranny out and found the main drive gear on the input shaft is worn out. I bought the "Deluxe" kit from this outfit in El Paso. They even threw in both sets of 5th/Reverse synchros! I got it rebuilt and installed with the help of a buddy's motorcycle jack. Muchas Gracias, Mike!
Now, it works like a charm in all but 5th. (Overdrive) It shifts into 5th without a problem but when I let out the clutch, it jumps out of gear.
I pulled the tranny (again!) Friday and broke it down. I thought I had put in the wrong 5th gear synchronizer. So I put in a different one. This one had larger teeth than the previous one and had teeth missing in 3 spots around the ring. (Just like the reverse synchronizer)
I got the tranny back in today, (Saturday) but its doing the same thing.
Any ideas? I'm stumped.
1580rick
mazda
I sure could use a copy of those repair instructions and a address where you got your parts. Thanks!!! gatar12557@yahoo.com
AllanD
TRS Technical Staff
135
East-Central Pennsylvania
1987... sorta
'93 4.0
Did you at any time disturb the "big torque nut" on the 5th/reverse shifter bellcrank pivot shaft?
the synchro with the missing teeth is the reverse ring.
the one with no missing teeth is for 5th.
The internal taper is different on the two rings
and the inner serrations on the reverse ring (if an all brass ring"
look for all the world like they are "pre Worn" because frankly tyou don't want the reverse synchro to be completely effective...
Ever "shift into sixth" at highway speed?
BOTH synchros on your trans should be the "big tooth" as ford
switched to the "Big tooth" synchros late in 1991
AD
kdowney50
2.3L SOHC
Did I what?!
As a matter of fact I did disturb that nut. I loosened it to get the shaft out during tear down. Is it possible I need to adjust that? How do I go about that?
I also noticed, during reassembly, the different internal taper of the 5th and reverse synchronizers. Thus, I was careful not to confuse one with the other.
And no, I have never shifted into "6th" at highway speeds, but it sounds scary!
rcwc28
tacoma washington
ford&mazda
2.3/both
oh i did kindof down the freeway and a nasyt buzz grind noise ooohh nastty
Grandpa's S/S
NC
Mazda
I have the same problem. I got 402k on my mazda and I and looking at a 4th tranny. The 3.0 version just don't hold up. My last rebuild cost me $700. I think I will rebuild mine this time or swap to an automatic out of an aerostar. I can do that cheaper. I could use a copy of the rebuild instructions myself if you can spare the time. I like my truck and don't plan on letting her down.
