5 speed 1992 Ford Ranger - Hydraulic Clutch line pains
RustRatz
22
Arkansas
Ford ranger
I had to pull the hydraulic clutch line when I pulled my engine/transmission and I can’t seem to get it back into place.
Any ideas?
kunar
131
Toledo, Ohio
5.8l
Obviously first, make sure there's nothing inside the port or anything like that, but assuming it's all good, crack the bleeder to let the pressure out as you ush the fittings together
scotts90ranger
4,420
Dayton Oregon
2.3 Turbo
That and make sure to slide the white plastic ring back to it's home in the back, if it's still pushed in it won't click in...
RustRatz
22
Arkansas
Ford ranger
How does that work? I cracked the bleeder and everything, but it still won’t work together
kunar
131
Toledo, Ohio
5.8l
Sorry for the delayed reply. It just lets the pressure out of the slave so the fluid pressure isn't keeping the quick connect from moving. If that's not doing it for you, you could have something else going on. Hopefully you've got it figured out by now though.
RustRatz
22
Arkansas
Ford ranger
Never did lol
Moved on to getting it running right. Doesn’t need to drive before it can run for longer than 10 seconds
Josh B
1,987
Oklahoma
I don't recall exactly why but the last one I did on my 93 wound up pulling it all completely out (even the lines through the frame and fender), assembling it all hanging from an 8 ft ladder and bleeding it there, then installing it all in one piece.
Also I'm not sure why but I still had to put that thing into the slave cylinder from underneath and although it was a total pain it did go together and work even till now, but now there's another leak
RustRatz
22
Arkansas
Ford ranger
I don't recall exactly why but the last one I did on my 93 would up pulling it all completely out (even the lines through the frame and fender), assembling it all hanging from an 8 ft ladder and bleeding it there, then installing it all in one piece.
Strange. I’m not good with the transmissions in these trucks, but I know the engines quite well.
kunar
131
Toledo, Ohio
5.8l
Never did lol
What style connector does it have, can you take pics of what's going on? If i remember, there was a gold connector with at least 2 different style clips (the plastic collar type, and the metal hair-pin type) and there was also a black connector, not sure how those were set up.
Josh B
1,987
Oklahoma
I had to correct a word in that Rust, "wound"
RustRatz
22
Arkansas
Ford ranger
I have the plastic collar setup in mine. I hate it tbh
scotts90ranger
4,420
Dayton Oregon
2.3 Turbo
I just did mine a week ago and it took some pushing and wiggling to get it in there far enough but it worked fine all weekend...
