oddball101
- Jun 8, 2010
- Reaction score
- 0
- Location
- Columbia SC
- Make / Model
- Ranger
- Engine Size
- 5.0
- Automatic
Shotgun attempt to get my truck running..
I have an 01 ranger with a 2000 5.0 (explorer) swap. It's gotten colder here and may have caused an issue. Got to a Walmart fine, wouldn't crank when I tried to leave. Only issue I have had in the past electrically was cable corrosion on the terminals, but I've kept it in check.
Situation:
Went to start and heard only a click. The motor didn't even try to crank. Tried beating the starter with a hammer, same result. Replaced the starter, same result. I should've checked fuses first but cannot dtsfmine which in the power distribution box. I'm looking for the starter relay or anything else related.
I read that the starter solenoid was attached to the starter but don't know of any other location to check. Next is me retracing my steps from a year ago to see if any of my solder joints broke.. My mileage stopped registering on the counter at the turn of 170k. I doubt the issue is connected, but it is another variable.
I want to leave the new starter in place until I figure out the problem. Any pointers would be real nice..
I'm looking for everything I need to test in the starting system. I don't have a volt meter.. Pretty sure the engine is getting fuel. Also hooked up a trickle charger on its highest setting. Tried starting after a few minutes and the terminals sparked while the charger was connected. Never saw that before.
Any ideas or suggestions?
It's only getting colder
Situation:
