4L bellhousing question
Bracket racer
Canada Military - Veteran
235
Socialist republic of Nova Scotia Canadastan
Ranger supercab
Crap load
35X12.5 (bald so I don't break parts)
Low range in Nova Scotia on YouTube!
Is there anything else that has the same bellhousing as a 4L? Did a search and can’t find anything conclusive.
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
If you mean the 4.0, then yes. The 2.9 has the same bell housing pattern. The 4.0 sohc has one more or one less bolt hole (can't remember) but it still fits.
8,372
Well the 4.0l OHV or SOHC never had a separate manual transmission Bellhousing, they were always integrated, part of the M5OD-R1 transmission case
The automatics had detachable bellhousings
As far as the bolt pattern, it used the Taunus/Cologne pattern, seen here: https://en.wikipedia.org/wiki/List_of_Ford_bellhousing_patterns#Taunus/Cologne_pattern
Some earlier model manuals for the 2.8l and 2.9l Rangers did use detachable bellhousings
+1 to what Dirtman said, the 4.0l SOHC engine added 1 extra bolt to bellhousing but same pattern, so they are interchangeable, you don't "need" the extra bolt or bolt hole, the rest of the holes and bolts line up
Bracket racer
235
Ranger supercab
Crap load
Cool, thanks guys. I was just wondering what other options I had if I swap out this coolant eater.
The 3.0 from a ranger won’t fit huh? Lots of them around and they seem more reliable.
Anyway, just looking at what else would bolt up to the 5spd.
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
The 4.0 OHV is one of the best engines the ranger ever got. The only thing more reliable would be the 2.3 lima but it's significantly less powerful. Swapping in anything else, especially a 3.0 would ultimately just be a step backwards and require alot more work than simply finding a matching transmission...
snoranger
Professional money waster
ASE Certified Tech
13,700
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
He could put a 2.9l in it. :icon_rofl:
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
Bracket racer
235
Ranger supercab
Crap load
If that's the case then I'll probably wait until a 4.0 comes along.
Thanks guys.
