4L bellhousing question
Bracket racer
Canadian Military - Active
136
Socialist republic of Nova Scotia Canadastan
Ranger supercab
35X12.5 (bald so I don't break parts)
Is there anything else that has the same bellhousing as a 4L? Did a search and can’t find anything conclusive.
Rock Auto 5% Discount Code: 7FA902352B4C01: April 5th, 2021
Dirtman
8,447
41N 75W
It's up there.
It's down there.
Round.
If you mean the 4.0, then yes. The 2.9 has the same bell housing pattern. The 4.0 sohc has one more or one less bolt hole (can't remember) but it still fits.
2,642
Well the 4.0l OHV or SOHC never had a separate manual transmission Bellhousing, they were always integrated, part of the M5OD-R1 transmission case
The automatics had detachable bellhousings
As far as the bolt pattern, it used the Taunus/Cologne pattern, seen here: https://en.wikipedia.org/wiki/List_of_Ford_bellhousing_patterns#Taunus/Cologne_pattern
Some earlier model manuals for the 2.8l and 2.9l Rangers did use detachable bellhousings
+1 to what Dirtman said, the 4.0l SOHC engine added 1 extra bolt to bellhousing but same pattern, so they are interchangeable, you don't "need" the extra bolt or bolt hole, the rest of the holes and bolts line up
Bracket racer
136
Ranger supercab
Cool, thanks guys. I was just wondering what other options I had if I swap out this coolant eater.
The 3.0 from a ranger won’t fit huh? Lots of them around and they seem more reliable.
Anyway, just looking at what else would bolt up to the 5spd.
Dirtman
8,447
41N 75W
It's up there.
It's down there.
Round.
The 4.0 OHV is one of the best engines the ranger ever got. The only thing more reliable would be the 2.3 lima but it's significantly less powerful. Swapping in anything else, especially a 3.0 would ultimately just be a step backwards and require alot more work than simply finding a matching transmission...
snoranger
Forum Moderator
ASE Certified Tech
4,572
Jackson, NJ
'79,'94,'02,'17
All Fords
He could put a 2.9l in it. :icon_rofl:
Dirtman
8,447
41N 75W
It's up there.
It's down there.
Round.
Bracket racer
136
Ranger supercab
If that's the case then I'll probably wait until a 4.0 comes along.
Thanks guys.
