4 link SAS+lift
cdawall
U.S. Military - Active
5
Ellsworth AFB
4.0L V6
3 link SAS+lift
its only a dana 30 I really don't want to hear how its not strong enough etc. its better than the dana 35 ifs I destroyed.
mock up height of the truck
this is with the leafs compressed+bilsteins
i need some better backspacing for the rims :/
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
Looks good, I would go for a longarm setup. Your going to be happy with this swap, I am with mine.
mhughes165
9
302
what size tire u plannin on runnin on that redic amount of lift for 33's lol
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
Ok, so I won't tell you its not strong enough, but I will tell you, you are mistaken to think and say that a 30 is stronger than the 35, other than that you have a nice truck there :icon_thumby:
SVT
cdawall
5
Ellsworth AFB
4.0L V6
35s might take the stock block out so it looks ok with the 33s until I can afford 35s
SVT
No the diff isn't stronger than the 35 however the straight axle is stronger than the ifs.
dangerranger83
54
Lafayette, IN
Still sounds like an upgrade to me. If it was shafts/CV's you were breaking then this SAS may be the fix.
What type of coils you going to be running?
cliffrat
seneca,il
89 ranger 33bfg
92ranger,35bogg
looks good .t would be to tall for around here .What coils and leafs are u using? I,m about to do the same
cdawall
5
Ellsworth AFB
4.0L V6
jeep 3/4 leafs i can't remember the coils
cdawall
5
Ellsworth AFB
4.0L V6
slight update....been a bit and everything is just about done
cdawall
5
Ellsworth AFB
4.0L V6
legoms013
09/2013 OTOTM
26
CA
4.0L V6
Any particular reason for sticking with the stock Dana 30 inverted y steering linkage?
escort_gts
02/2012 04/2013 04/2014 OTOTM Winner
16
Fort Wayne, IN
4.0, 5.0
That is what I used and it worked good enough. If the jeep guys use them with upgraded tierods...
Toreadorranger
5
Sal
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
but, is a shiny turd a successful turd?
how does one gauge that?
its a rapid cause of infamous jeep d.w...
good enough for now, but tears up tires still and when the cash is there getting a hi steer knuckle is advisable bud
