4.0 OHV as an overland engine
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
I have to agree with what's been said above, the 2.9L and 4.0L are more similar than different. Mine's been flawless as for reliability (excepting for extraneous crap like a blown alternator), and it's easily got over 300K on it now (and I'm not particularly nice to it either).
The 4.0L swap would make sense if yours has issues that require a rebuild (low compression, worn cam, bearings, oil burning, etc.), and is what I intend to do with mine, should the 2.9 ever quit. But reliability alone IMO isn't a good reason to swap. Both engines are great in that department if you keep on top of your cooling system maintenance.
Another aspect is parts
2.9l was used from 1986 to 1992, 6 years
4.0l OHV was used from 1990-2000, 10 years
302 was used from 1968 to 2001, 33 years
You're one year off each time
1986-1992 is seven model years of production, and so on.
Your point still stands though (however I would question how many similarities a 2001 engine would have with a 1968 engine... Many things will have changed simply due to fuel injection, emissions, and other improvements over the years, meaning things like sensors and other components will be specific to a much narrower set of model years).
8,370
oops, forgot to carry the ONE, since there was no ZERO :)
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
The 2.9 ain't dead yet and I do plan on running it until it dies. Compression is decent and it doesn't burn much oil at all.I run a 4.0 radiator and it stays cool no problem. I have a rattle from 2500 to 3000 RPMs that has me baffled. I am guessing is lifters. If so, then its new cam and new valve train. At that point, I might consider the swap more seriously.
snoranger
Professional money waster
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
It’s a 2.9L... if it’s not rattling, it’s not running.
17,867
SW Iowa
I really do love my V8 swapped truck but the thought of leaving about a hundred mile radius of my house with it makes me very nervous. I used parts from sooooo many vehicles, some of which I don't even remember now...that's why I built my Explorer for out of state travel... everything is either stock '92 parts except the rear axle.
My truck is the same way... it is as good as anything else in my fleet. I have parts from 8 vehicles in just the air filter assembly.
Two years ago I drove it from an hour east of Omaha to an hour west of Pittsburgh. Last year I drove it from an hour from Omaha to just into Indiana. Hoping to do it again this year.
Half wore out $200 302 uses a bit of oil but runs great, 18mpg and it didn't miss a beat. It took a lot of work but I have no regrets.
Junk Collector
Truck of Month
4,806
Rapid City SD
I wish mine was like yours. I'm just used to breaking down... a lot... I guess I did daily drive it a whole winter a few years back when my 4 cylinder was at the machine shop and it didn't let me down then...
Someday I should do a cross country trip with it and have someone follow me, lol
17,867
SW Iowa
I suspect you probably go looking for a little more trouble than I do too. I avoid the deep water and big rocks... after I get done playing I have to drive it 10+ hours back home. But your truck is much more of a crawler than mine too...
As far as staying stock, while nothing is actually stock I kinda did. It is basically a F-150 in a smaller wrapper down to the tire size.
Never a bad idea with an older vehicle. I had my FIL follow me in '19 in case I had problems because it was like a month after I wrapped up a t-case/tran/front axle swap. Last year I had three butts and two seats so he had to tag along again. No security blanket tow pig if I had problems, he was pulling a camper that time because it was going to be cold and we had our 9mo with. This year if everything works out I will be convoying with my wife and her new Bronco.
Always looking to expand our convoy to the Roundup @Shran... its not that far down to here. :icon_idea:
And OP, I know you said you didn't want a V8, and I am not trying to sway you. Not sure exactly what to call this but I am not trying to derail your 2.9 -> 4.0 swap thing. If you want more info on a 5.0 don't keep it to yourself otherwise I am really going to try to stay quiet about it. No guarantees but I am going to try :dntknw:
