Yes, The Mitsu's and the TKs could be bolted to the Sho but, It wouldn't be advisable. The M5r1 is going to be pushed to its limits.
It's Not "horsepower" that breaks drivetrain components, but "torque"
And the SHO doesn't make as much torque as a 4.0OHV engine
I think even a stock 3.0 gearbox would be "fine" behind a SHO engine
for durability, butyou'd likely be happier with the gears from a 4.0 trans
for the different gear ratios (the 4.0 M5OD-R1 is essentially a "Close ratio" trans)
BTW, don't refer to our Mazda M5OD-R1's in "shorthand"
because there is another completely different transmission
that IS an "M5R1"
what mutant said. if you find one of the rare detachable 3.0 bellhousings, you could bolt it to an FM or TK..but i wouldnt. the only ranger SHO swap ive seen used a T5 (mustang) trans...it would be interesting to see how the M5OD handles 220HP...
Again, it's not the "power" but rather the "Torque"
Stock 4cyl Mazda's have withstood being behind 2.3Turbo's
which when "tuned up" make the SHO motor look worthless and weak.
You can easily tune up a 2.3T to the mid-250's (HP) and
they already make far more torque stock than a SHO engine does....
Remember, Wicked_sludge, it is torque that breaks things. The M5OD will handle it just fine until you dump the clutch at about 5000 rpm. Then it is a 100% gauranteed failure.
You made me remember a detail I forgot, it's torque AND rotating inertia. Dump the clutch at 6grand and you'd likely snap the input shaft, the rest of the trans would be undammaged
Hey ive built 3 of the normal ford 3.0 motors now ive left the block and rotating assembly stock im jw if any one has any ideas if how to push out 250hp and 240 trq just on bolts ons without breakin the bank im roundin out at about 205 on the one i just got rid of stock it was 168 and i only spent about 450 on it. Any ideas?
Get a grip and don't insult my intelligence.
You are making 205 out of a vulcan without forced induction like I'm the Queen of England.
It takes Dual Overhead Cams, four valves per cylinder AND
spinning the engine to just shy of 7-grand to make 220hp
what makes you think a 2Valve per cylinder pushrod turd
is gonna make 205 without a nitrous bottle?
As for the arguement about power, horsepower is horsepower.
two vehicles with the same power and proper geaqring for the specific engines will be equally fast.
the other advantage to the 3.8 Split-Port is that NOBODY is looking for them there are atleast a dozen in each of three junkyards and they are always in the junkyard for the same reason.... The vehicle they are in has a dead automatic trans.
yes, a peaky engine can be "fun" if you know how to use it
and you have the inclination to use it, but trust me it gets old
faster than you will.
BTW, an engine that you MUST keep spinning at 4000rpm plus simply so the vehicle keeps moving attracts attention from all the people you don't want... thieves and police.
I long ago learned to be more "discrete"... you can have a car that will do 140mph until you run out of gas, but if every time you go 3mph over the posted limit there's a cop with a ticket book and an itchy pen hand you get to feeling stupid faster than I can type the word "jackass"...
My only problem was that the local cops where I lived didn't stay stupid...
AD
