2019 Ranger Missing 2 of the 6 Bed Tie Down Brackets
sgtsandman
Aircraft Fuel Tank Diver
12,652
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
So I see. Thanks for the info.
Then, the factory should put dummy/filler bolts there...
About the four tie-down hooks, I guess Ford has made it a permanent configuration since the year-long parts supply shortage problem can not be resolved. Can other 2020 Ranger owners confirm?
While I can't disagree, fasteners are expensive. Based on what I've paid for fasteners in various projects compared to other materials, fastener cost adds up quick. I doubt Ford or any other vehicle manufacturer is going to agree to pay for that, let alone plastic filler plugs. In the end, it comes down to the bottom line and if they don't have to front the added cost, they aren't going to.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Fasteners are for fat people and guys named Lance.
SymChris
9
Mississauga, Ont., Canada
Ranger Lariat
2.3 EcoBoost
The omission of the 2 tie-downs was a running model change in mid 2019. This was an intended removal, nothing to do with (and prior to the covid-caused) part shortages.
I consider having them as an "early adopter perk" :)
(same with the rear seat fold-down headrests, although I think those were just a delete for 2020 and later, not a mid-year running change)
James Fremont
Pacific
Ford Ranger XL
2.3 EcoBoost
225/70R16
Thanks for the clarification.
That might be as well, I am sure I can find good use for the tapped M8-1.25 holes there in no time. Ideas are welcome, of course.
SymChris
9
Ranger Lariat
2.3 EcoBoost
You could get still get the tie-downs if you wanted/needed, but as mentioned earlier they really jacked up the price on them. Most likely why the Ford bean-counters decided to remove them.
sgtsandman
12,652
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
The third pair of tie downs, at least in the Supercrew trucks, is of minimal useful value for most people. They are handy for me to keep tool bags and some packs in place near the back but for the average cargo hauling, aren't super useful. The ones in four corners have much more utility.
HenryMac
382
Central Colorado
2019, '31, '27
Ranger, A & T
2.3 Turbo, 350, 5.0 HO
Stock, about a foot, about a foot
LT 265/65 R17, P285/70R15 & P195/65R15, 820-15 & 500-15
This was an intended removal, nothing to do with part shortages.
I'm curious, where's data to back this up? Sure, there was a memo issued in the factory to just install (4). That in no way means it was an intended removal. The brackets are backordered at the dealership, and the prices are soaring on them. If it was "intended", why does the bed still have the tapped holes. There would be cost savings to eliminate those, but they haven't.
Did you know Ford also shipped Rangers without any seam sealers on doors... was that also intended?
Some of Ford's competition has well engineered tie down systems, meanwhile Ford is deleting simple mechanical brackets. It makes no sense at all. It's a truck, made to haul things. Securing those things is very important. Ford did a piss poor job on this IMO.
I find "The missing bracket locations" to be more useful than the front or rear hooks. I feel those, especially the front ones, are way to close to the front and rear and would be better if moved away from the bulkheads. Run a strap across the front and they are inches away from the front bulkhead. Especially with a factory ToughBed liner, because they add that big dopey plastic Ford logo before they spray in the liner.
BGTruck
Virginia
I disagree. They are perfect center point tie down locations for motorcycles. I want them. 30 bucks a pop for a simple bracket is nuts. My old F150 tie down rings were 7 dollars years ago and I though that was ok.
Abox5
21
Tennessee
Ford Ranger XLT
2.3 EcoBoost
I wasn’t going to pay those insane prices for a bent piece of bar stock with two holes in it. So, I made my own. Cost about $12 in materials and about 3 hours to make 2 of them. I bought the bolts at Ace for $4.
HenryMac
382
Central Colorado
2019, '31, '27
Ranger, A & T
Maybe swap your homemade brackets for the front or rear factory ones, then put the factory brackets in the center? The recess that's built into the bed wall allows you to route a larger clevis or use of a heavy / thick rope or strap to be used.
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
If you factor in whatever those 3 hours would of paid you at work, did you still end up saving money?
fastpakr
2,834
Roanoke, VA
You're assuming he took time away from work to do this. I don't know about you, but I do car projects on my own time. And, most of the time, I enjoy it as a break from other things in life.
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Eh not quite.
I'm having a hard time trying to think of a way to explain it good lol... hmmm.. damn.
I guess giving an example is the best I can do.. here goes..
It was always "worth it" to me, in the past, to do all my own basic maintenance and whatever repairs I can easily do myself to save the money.. and like you said.. the enjoyment was another factor.
Now, I make quite a bit more at work than I used to. It's now more "worth it" to me to just pay the dealer 65$ to change my oil, rotate tires.. whatever. Id rather spend the money to have more free time. When I can use time from the work week to pay for things I used to pay with from time from my weekends.. I'm all over it.
If two hooks and 4 bolts from ford cost say.. 75$.. and the OP makes 33.33$ an hour.. then he's more or less lost 25$.. kinda..
It's really a workaholic mindset.. or one of someone who really desires to maximize their time. I understand it much better than I can explain it unfortunately.
fastpakr
2,834
Roanoke, VA
I understand what you're saying. But if he's doing this on his own time where he wouldn't be paid for it otherwise, you really can't apply that analogy the same way. It's not taking away billable hours. There's still a personal decision of whether it's worth your time, but it's compared to what you might -want- to be doing rather than what you'd be -paid- to do.
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Right on, I can see the difference definitely. Analogy doesn't exactly work.
The people who I've had describe to me that (their) particular mindset though.. don't try to convince them there's a difference lol. Workaholic doesn't even begin to describe these folks. If it doesn't make/save money then it shouldn't be done, and something that DOES make or save money should be.
