2.9l top speed
dangerrangerva
2.9l
them chips aint much are they
CROW T. ROBOT
Taber, Alberta
2.9
I think 4.0B2 hit the nail on the head, get rid of the 4.10's. You could get a 3.45 with the 7.5" which should still be enough to get you going, plus your engine won't be screaming at highway speeds.
4.0B2
151
Walls, MS
4.0 v6
what size tires do you have?
somethings wrong.... does your TC lockup? do you have OD at all?
at 75 with 205/75/15 tire size.. you should do 70 at a little less than 3000 rpms..
here, go here.. fill it in, look at the numbers
http://www.grimmjeeper.com/gears.html
4.0B2
151
Walls, MS
4.0 v6
and 85 at 3339 RPMs..
i wonder if you have OD or not
dangerrangerva
2.9l
i have 31s and in 4th gear (highway) is normaly around 3500 to 4000 3.73 gears about 80 85
Z3CHYD
17
Lancaster, PA
3 front 5 rear
225/60R15
I've had my 86 2wd 5-speed 2.9 up to 109...had gps on to tell me how fast i was going lol. I'm not sure what gearing is in my rear but I know it's from an 88 4x4 ranger, it runs like a raped ape lol. and bump i guess lol
Winchester, Tn
Dodge
5.9
I had a ranger just like yours before i got my current ranger and it sucked speed wise. IMHO a 2.9 should never have an automatic behind it, because my current ranger is a 4x4 5 speed with 30" mud grips and 3:73 gears and i have had it up to 110 at 4200 rpms. i cruise down the interstate at 70 turning about 2800 to 3000 RPM's no problem. Just my $0.02 worth
Lucas
86ranger4x4owner
2.9l
It has 31s. I had it on the interstate at 70-75 at 3000 rpms but i think it would go if it had a 5 speed. How much would it cost to swap in a 5 speed and would it be a straight swap?
jaymegriffiths
7
Regina,Saskatchewan
2.9
I had an 88 2.9 5 speed 2wd goin 107 and still accelerating, had to slow down for traffic. gps confirmed
Desert Jim
Crestline, CA
177
Gears. I had a 95 2wd with 32's, the 4-banger and 4.88 gears and it would run up to the governor in 5th somewhere around 90 - 95.
PGHFord
Pittsburgh, PA
2.9L EFI
If you can find one, A Merkur Scorpio, our rangers 2.9L was used in that also, it has a different intake plenum setup.
Branene57
Payson
Ford ranger
I have a 1988 ford ranger 2.9L 5speed 4x4 with 31 inch tires new motor has like 200 miles on it and it is slow like going on a straight away it slow to get up to speed and i put 5.0 injectors in it and it is still slow I drove a Friends ford ranger just like mine with 31inch tires 5 speed and it is way faster then mine so I have no clue what to do... PLEASE HELP
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
What gears do you have, and why did you put 5.0 injectors in it? It accomplishes nothing. In fact if they are rated for higher lb/per hour than stock you're only going to make the engine run like crap.
Branene57
Payson
Ford ranger
I have 3.73 gears and my friend has 5.0 Injectors and it runs good and no lag
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
Maybe it's broken.
