heptofite
- Oct 25, 2009
- 62
- Ford Ranger
- Engine Type
- 2.3 EcoBoost
- 2WD / 4WD
- 2WD
larger bore, shorter stroke, higher stock ratings, more cylinders, more displacement.Power wise, I think you might as well go the V8 route or even the 4.0 route. Frankly, if it's your DD, I feel that you would run into more issues than needed when it comes to something you rely on everyday. That's for turboing the 2.9 / 4.0 or V8 swap.
I can understand being hesitant about turboing a 2.9 and I've seen it done on here before with good results (IIRC). However, I feel that honestly the 2.9 is doing the best it can in it's stock form.
I don't know about beating out a 2.3 though....
Where'd you get that from? Not being an ass, I'm serious..
It'll rev higher and it's bigger.
it's the same work either way to convert an N/A 4 cylinder block to be able to use it for turbo'd applications as it is to do the same to a 2.9, the SINGLE AND ONLY advantage the 2.3 has is that it was available as a stock turbo'd engine.
if you're shooting for the moon anyway, you're not going to stick with the stock parts anyway, so may as well start out with a superior engine.
edit:
the cosworth 2.9 made 210hp on inferior combustion chambers and identical bore and stroke simply because they pushed more air through it, a turbo does the same thing, and if you'll notice the upper figures for TURBO'D 2.3s is 210hp in stock applications.
quite frankly, i'm sick of the notion that the 2.9 isn't worth it and the ONLY solution is to do whatever the **** everybody else is doing and just throw more engine at it.
i don't abide by the notion that the 4.0 is the only 'upgrade' for the 2.9, or that a V8 is the only way to get power.
so you know what? Challenge ****ing accepted, stay ****ing tuned for the results of what i'm going to do.
