The most research I’m doing seems like this engine takes a different kind of pcv and the one I have on it is bad for sure. So I’m on the hunt to buy one. And I’m checking to see what other distributor I can use and going to make my own if possible duraspark kit. What I did find out a Mustang II might be the winner and it’s has point but will need an external coil. But more to come with that as I’m researching.
I am cheap. I just did this swap about 4 months ago. It's worth it. The hard part is finding a distributor. Parts for the 2.8 in the broncos and rangers is getting very difficult, finding 2.8 parts for a 70's pinto or mustang II is even harder. Everyone has to order it. I bought a distributor for a 1978 or 1979 Mustang II. I think the pinto is the same also.
My favorite place to get parts, rockauto is kind of a let down on this. They only have some sort of rebuild service. Hard to rebuild something you do not have in the first place.
I kept my eyes open for old pintos or mustangs sitting around locally, but most of them had 2.3 4 cylinders.
I can't remember exactly where I finally bought it from. It may have been Advance Auto. You can easily find a 20% off coupon when you go to their site or google it. But you can't pick it up in the store, you have to get it shipped to your house, they don't stock it.
Then I found out they had two different brand distributors Ford used. A motorcraft and a Bosch. I had no way of knowing which one they were going to send, so I had to wait, they take different distributor caps. They sent me a motorcraft. Found out the cap on the TFI distributor will not work. I had to go to the local store and they had to order it, the top part was a couple days to get, and the cap adapter on the bottom was a week to get. I suppose the top was possibly the same as a 300 six used, but the bottom adapter was 2.8 only.
Being cheap and wanting to use the original square TFI coil, I opted not to use the duraspark II ignition box, but instead bought a GM HEI module. I mounted it on a heatsink on the driver's side inner fender and wire it into the duraspark II distributor like this article explains. It works very good.
Feeding the coil with 14 volts instead of 7 improves spark intensity, improving throttle response, fuel mileage & even adding a bit more power.
www.streetmusclemag.com
