tpginmaine
- May 26, 2014
- 1
- Maine
- Ford
- Engine Size
- 3.0
Hey All,
Been fixing this thing up for a couple months now, getting ready for inspection. My CEL has been on for a while & I've been trying to trouble-shoot that, but it's been driving great, so wasn't top priority. Unfortunately, this week something changed dramatically. It idles ok. Sometimes maybe a couple hundred too high? Not sure on that yet. That may be intermittent or just temp related, so spring in Maine means temps are all over the board from hour to hour. Anyway, this isn't a change compared to two weeks ago.
The problem is that under higher RPMs, approx 3k or more, it suddenly sounds like a jet engine. REALLY loud. Best I can explain it is to take the regular 3.0 engine noise and add one of those turbo hand-dryers found in public bathrooms. You can barely hear yourself think in the cab! I stood in front of the engine the other day and had my son rev it to 3k to try and pinpoint the where the noise was coming from. Not only could I not pinpoint it, it was so loud I was uncomfortable standing in front of it. Literally like too close to a jet engine. I definitely have a loss of power, too. It will purr down a straight-away at 60MPH, but hit the gas to pass & it starts screaming! It will down shift and accelerate, but feels like it's towing a boat or something.
The CEL code has been P0401, EGR flow insufficient. I cleaned the EGR valve last fall and it worked fine. I just checked that it holds vacuum, so I don't think there's a leak there. It holds vacuum from the valve to the solenoid, and there's good vacuum into the solenoid. So I thought it might be the solenoid, and I replaced that a couple weeks ago with no CEL luck.
The past couple days I've tried 1. Driving with the EGR vacuum hose diconnected, 2. Driving with the solenoid plug disconnected, 3. Driving with the DPFE sensor disconnected. No change in "screaming" or power loss.
What now?
What now?
