1989 2.9 ranger: journey to passing inspection
racsan
4,441
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
those rims were common as could be in the late 80’s/early 90’s and are scarce now. too bad they are 14’s. if you could, build a matching ranger trailer & those rims could go on it. that bed is in excellent shape, too bad the rest of the truck wasn’t saveable.
Oaktree22
12
Northumberland, PA
Yea, we'll make good use of anything we can tho
Oaktree22
12
Northumberland, PA
We've got the truck all cut apart now, we couldn't use any of the front, it was crushed, so it's going for scrap, we hacked the frame off just behind the rear cab mounts, since it might be useable for patchwork. We pulled the engine and trans, I can pull apart the engine to see if there's any parts that could be sold. One of the rims is bent in the back, but if someone wants or sees a use for the set then we could talk about it.
43847
43848
43849
43850
43851
43852
Oaktree22
12
Northumberland, PA
Been a while since I've posted on here but I figured I'd give an update for anyone still following, we spliced the frame from the donor truck and everything has gone smoothly so far, now it's just a thing of painting the frame then putting it all back together.
63075
63076
63077
RobbieD
2.9l Mafia
3,453
Georgia
Looking good! (y)
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Good progress! I lost my father just before I was old enough to do projects like this with him, unfortunately. Enjoy the time and the learning experiences your sharing with him.
scotts90ranger
4,368
Dayton Oregon
2.3 Turbo
I would HIGHLY recommend putting a fishplate on the inside and/or outside of the frame, just a butt weld like that is way too much stress concentration in a very important area.
In case you aren't familiar with a fish plate, it would be a <> shaped plate at the seam to get welds going in different directions.
Other than that, looking good!
Oaktree22
12
Northumberland, PA
We cut the back half so that it slid into the original frame, then ran bolts through as well as welding it, so it isn't just butt welded together, I do see what you mean tho and we thought about that before welding. I'll see if I can get some pictures of it here in a minute.
Oaktree22
12
Northumberland, PA
63269
63270
The welds aren't perfect but with how secure everything is we had 3 guys standing on the joints and didn't hear or see anything that would raise any red flags.
scotts90ranger
4,368
Dayton Oregon
2.3 Turbo
Fair enough, that should do, it looked like just a butt weld :)
Oaktree22
12
Northumberland, PA
All the parts just got here today so we'll be starting to reassemble the ranger, hopefully everything goes smoothly
Oaktree22
12
Northumberland, PA
Well things are happening but I'm trying to set up the parking brake and it's the dumbest thing I've ever seen
franklin2
1,758
Virginia
I know what you mean. Pull on one cable that is not even mounted and when it stops and gets tight it starts pulling on the other cable. Someone was paid a big engineering salary to come up with that one.
Oaktree22
12
Northumberland, PA
Well she went down the street under her own power for the first time in a while 🤠
