07 level II YELLOW submarine
MaicoDoug
55
Texas
Ranger FX4 LVL2
2 inches in the back, not enough in the front
32x11.5x15
The're on their way...
Oiled paper packing +
I sanded the crate with 33 grit sandpaper 'cuz unclegump wants 33s
As compaired to 0 grit sandpaper, which is actually a cinderblock. Works great for "block sanding".
-Doug
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,575
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Thanks Doug...
I'll keep an eye out for them.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
MaicoDoug
55
Texas
Ranger FX4 LVL2
32x11.5x15
PJ, great question....
Eibach stocked nothing between 700 & 800 lbs. So thinking that the 700 pound spring would be too soft, I went with the 800 pound model. The spring preload is about 1.25" on the shock body. For a "2.5 inch I.D." spring, there must be another manufacture out there that would stock a 750lb/2.5" spring. The other adjustment is the shock nitrogen preload. I considered going with a "dual rate"spring setup, may still give it a try. Springs are cheap.
Right now with this coilover mod, the front suspension has gained 1.5" of additional travel. I had been having interference issues with the 31 inch tires rubbing the inner fenderwell, currently that problem is solved. So currently after some 5kmi on the suspension lift with these coilovers, I would say that they must be some more adjustment to make the ride a little bit softer. However, not wanting to loose much travel, I am considering adjusting (lowering) the shock preload pressure. Other that that, a winch & a pre-runner style front bumper will weight it down. Which is really the next step now that the coilover modification has proven itself out and the "cement truck" style of ride quality is gone. Getting ready to fab up some longer A arms. But sourcing longer axles are the issues here. There have been roomers of some longer china junk axles. I like to go fast, an old desert racer.
Planning on hauling the Ranger to Durango for some off roading in the very near future. Just an axle dolly pulled behind the F150. I believe that keeping the yellow sub level 2 as stock as possible maybe what happens in the long run, and pickup a 2wd and go crazy with it. The 4wd ones are around. I see them often.
- Doug
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
- Doug
Doug,
That makes a lot of sense.
Did you wind up putting the extended eyelets on the coilover bodies, or running them as is?
As of right now, I am about maxed on my suspension - combination of #1 bars and a set of leveling keys. Ride quality is that of a brick, combined with a front sway bar links life of a few weeks. So, dropping down an inch or two is the goal, and coilovers seem to be cut out for the task.
Brackets were ordered yesterday.
MaicoDoug
55
Texas
Ranger FX4 LVL2
32x11.5x15
Yes, I am running extended eyelets. It's the only way to have anything out and away from the axle. Found them also at https://www.kartek.com/ for 25% of retail. Crazy deal for an OEM Fox Factory part.
Uncle Gump
Token Old Guy
13,575
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Torsion bars showed up today...
I haven't un-crated them yet... thanks Doug!
MaicoDoug
55
Texas
Ranger FX4 LVL2
32x11.5x15
Don't worry about the splinters, I block sanded the cedar. Enjoy friend.
