mrmordun
- Mar 30, 2014
- 2
- Ford
- Engine Size
- 4.0
- My credo
- Doing what I can with what I got.
Starting to do the the run down on this. Fuel cap is good, all vacuum lines appear good so far. I at the point where I getting ready to check the canister purge valve, now I'm a bit confused.
I see that there is a Vapor Canister Purge Solenoid and a Vapor Canister Vent Solenoid available.
I thinking the vent solenoid is the small part back by the fuel tank with a 3 wire connector and the purge solenoid is the one under the hood with a 2 wire connector. I get how to test the purge solenoid with the 2 wire, but the vent solenoid with the 3 wire is throwing me. Any one knows what the 3rd wire does and will the vent solenoid throw the hated P0446 code?
As an aside, this is the only code in the system. Truck runs and starts good.
