- May 13, 2009
- Age
- 35
- lisle ontario
ok so its been real nice so ive been doing the more boring pain stuff that i wouldnt motivate myself to do in the rain. such as fixing the brake line that i knicked when i did the springs
first i went and found where the hole was again.
then i cut the bad spot out
B4 you do ANYTHING ELSE slide the new fitting over the line. if not you will get the flare on and it will be perfect and you get to cut it off and so it again lol.
next i cleaned the inside out making sure that the 3/16 flare die (whatever i dont know the technical name) fits inside the line, then clamp the line making sure that it sticks out the same as the width on the wide flat part of the die.
take the press and with the die in the line. (MAKE SURE ITS STRAIGHT) sqiush it down until the die hits the clamp.
then remove the die and the line should look like this
then press the clamp down on its own into the line to get the double flare you need. dont go too far with it though.
then repeat this prcess all over again on the other line if needed ( mine was in the middle of a line. so i had 3 connectors 2 males and a double sided female connector)
tighten it all back up and bleed the system. mine leaked a bit so i just snugged my fittings up and done! no leaks
