waynaferd
- Jun 28, 2010
Here's the plan on a 96 2x shortbed ranger.....My rear rails are rusted out about 6" in from the rear (spring eye resting against 2x4 under bed, ratchet strap holding up bumper), and in plans to repair that, I have some thick 3" tubing to use for a c-notch, and another length for a crossmember or two. That way the repairs will be plenty strong.....
So in the rear I want to do the easy DJM axle flip brackets, with c-notch and new OE style hangars/shackles(no add'l drop).....
In the front I want to either cut or buy 2" lowering springs, and do poly pivot and radius arm bushings. I did the bushings on my lifted 94 f-150 4x and what a difference!! I don't want to get carried away with drop beams and such, as I have a b-b-b-b-budget. And a small one at that
Anyway, would the tail-dragging stance affect handling? I should also mention a heavier 302 is going in in place of the 2.3, and the battery will find its way to the bed.
Also, would stiffening up the rear of the frame cause more stress to other parts, like the forward parts of the frame, or susp?
The only other thing I can think of is I'm swapping from manual to power steering.
Right now I hit a bump or heave and I bounce and sway all over the place, partly due to bad shocks, partly due to a sliding on a 2x4 rear spring eyelet.
Any suggestions or horror stories with a 2/4-5 drop? Let alone with 5.0 power?
Thanks for any!!!
Thanks for any!!!
