87 fuel pump swap
Featured Build Threads
Friendly_RangerMan
Forum Member
Chino Valley
AZ - USA
Vehicle
Drive
2.9L
Stock
Stock
235/75R15
Hey guys, got an 87 ford ranger 2.9 that leaks gas. It’s leaking from the fuel bowl that sits underneath the driver side door, and I can’t find a replacement for the fuel bowl. So, my solution is to swap the whole system over from the 2 pump system to a single pump system. I just wanted to ask what my options are here…should I grab a pump from an 88 and take the fuel bowl/second pump out of the line? Or grab something from a newer ranger? What’s my best option here?
Also any tips or tricks would be helpful. Thank you as always:)
I just did this a few weeks ago. I used the stock sending unit and a Kemso pump.
Then ran all new lines, but you could just jumper the reservoir and in frame pump. I've heard of it being replaced with a stock filter for a later model.
I like this. I didn’t know they sold aftermarket pumps that would fit the sender…I think I’m just going to go with running all new lines too. I’ll come back later when I do it, I’m sure I’ll have some questions.
Yeah, you have to use the 88 and older sender but you can get a pump for an 89+
The fuel gauge uses a different resistance in 89+ so you use the older sender assembly in the tank.
Personally, I’d replace lines. It’s a pain and an expense, but we are closing on 40 year old lines. The ones on my 89 and 92 pinholed. My green 00 they started blowing out.
Dorman makes stuff to do factory type lines. I did -6 AN on mine, but I use AN for other stuff too so I saw no reason to buy into the Dorman system too. Use the PTFE line if you go with AN.
Just going to buy the parts and doing a little more reading on it, and I’m wondering if my solution is actually better? Supposedly the 2 pump system works well, so would I be losing any sort of performance by switching to the single kemso pump in the tank?
Simplicity was my reason for doing it. Fewer parts means less to go wrong.
You don't lose any performance by going to a single pump. That's exactly what they did starting in '89. I have converted multiple trucks and have no regrets and honestly I think the high pressure, in tank pump is more reliable.
The 2 pump setup works fine as long as it is working but if you introduce old parts, obsolete/no longer available parts, and aftermarket junk into the mix, it quickly becomes a lot less reliable.
Alright sounds good, I’ll pick up the rest of the parts I need today. Thank you
What do I do as far as wiring goes? Which pump currently primes everything when I turn the key and do I need to make it so the new in tank pump primes everything?
IIRC both pumps kick on with the key. Lift pump to prime the high pressure pump and high pressure to prime the rail. So a single tank pump is actually less stress on the aging electrical system
What diameter line do I need to buy? And how do I work with the quick connect stuff, does somebody sell new fittings for both the tank plug ins and up by the fuel rails?
Factory line was 5/16”
3/8” is also an acceptable size
Dorman sells the factory style line and connectors plus a tool to install the ends.
I went with AN stuff because I use it for other things on vehicles and such too and didn’t see a need to buy into another system. AN is the more expensive option though. I went with the PTFE -6 (3/8”) braided stuff.
Event Coverage
Featured Ranger Based Vehicle
