Building to last
Featured Build Threads
@Robert Mangrum You're right! 💪 I can do this myself, I'll just rent or buy the tools I need, read up on the articles here, and cross reference the manual.
@lil_Blue_Ford Thank you for the names of the spray, video reference, and telling the difference on the 35 or Hybrid this helps :)
09/090- Just ordered the shocks off RockAuto-
KYB KG5489 (Increased Handling/Stability) Gas-A-Just Monotube
Exc. High Ryder Option
I will update with pics and the replacement :) What happened to their customer service line?
Rockauto hasn’t had a customer service line for awhile. Also part of why I stopped dealing with them
Say hello to my new shocks-
Building to last
I'm not going to use profanity but I'm ******* elated! 🤩
09/15- after driving my truck for a good minute I parked at a store and noticed that there's a bit of a funky burning smell going on.
Sorry but these pictures are pretty crappy. 😣 so is the video.
Pic 1- the underneath.
Pic 2- view from the top of a lil leakage from the new water pump.
  • Building to last
  • Building to last
Whatever is leaking that much should be low. Looks like oil to me but it's hard to tell after run down a dirty engine/transmission.
I keep checking fluids but there's not a noticeable difference.Today and tomorrow I'm going to put a trap down and really clean underneath.
Dumb question but is a old grill brush ok to clean with?
Stiff nylon would be better.
@RangerThings
It looks like you used ReD RTV to seal your water pump; did you also use the standard gasket?
RTV:
1) let it set up 3-4 minutes before bolting on the components
2) once the component is bolted on, the RTV needs to firm up for approximately 1 hour before final torque is applied; otherwise the final torque may squeeze the sealant too thin 😭
3) RTV will not be FULL CURED until after 24 hours, exposure to fluids prior can erode of penetrate the seal when not fully cured.
Oven cleaner or degreaser (my favorite is ZEP) will take clear 95% of the mess you have pictured. Afterwards spray it off will the hose or a spray bottle of water. The water does 2 things;
a, it dilutes the cleaning solution residue
b, it rinses
@RangerThings
RTV:
b, it rinses
Thank you for your help 😁
09/25- bought some seafoam deep Creep and applied so that I can get to the ball joints a bit easier. Ordered Mevotech ball joints off RockAuto and hope by the time that they get here I'll be able to pop them off a bit easier than all the horror stories I'm reading.
Ball joints on the 93 4x4? Don't even try them without the press. With it takes longer to figure out the correct sequence and stacking order than it does to press them out and new ones in.
@RangerThings
RTV:
b, it rinses
Permatex has a 90-minute gasket maker RTV in regular (black) and high-temp (red) versions. The application is supposed to be ready for fluids after a 90–minute cure time (see directions for details). I've used the black version before, most recently on the cork gasket used with the Spicer differential cover I recently installed on my Ranger, and it works. Could save you some down time.
There’s also an oil resistant Ultra Grey that is available in both normal and “minute” ready versions. The quick stuff was in a dispenser can and I used it on a rear and also on an oil pan (fun fact, 2012 Nissan Murano the oil pan has no gasket from the factory, it’s a grey RTV).
Upcoming TRS Events
Featured Ranger Based Vehicle
