What coilovers should i buy? and more info about the coilover conversion kits
Got a call back.
Fox part number Fox 980-02-006 is being replaced with part number Fox 981-20-106.
Same coilover. New part number.
And i think ima go for the adjustable valve. Probably never use em. But at 160 per side, better to have and not need...
Hey brother.
I just finished my coil conversion and am currently driving it from NH to UT. I hope I can explain this well. The 6.5 is too big for a stock ride height truck. Maybe if you have a RC or super lift they’ll fit, but I am not sure. With the extended eyelets required for 4x4, the compressed length is too long and the shock will fully compress before the bump zone. I ordered the 6.5s from shockwarehouse about a month ago and they came quickly. After finding they were too big, I overnighted the 5s from kartek. Would order from kartek again good people. The 2.0 x 5 works well with oem towers and stock ride height. I preloaded the coils to level out the truck. If you’re going to weld on new towers or have a lift that changes things a bit. The confusion on the part number if I understand correctly is fox is trying to see you the new gen elite series. 980-02-006 is the part number for the 2.0 x 6 and 980-02-040 for the 2.0 x 5. If anybody is looking for 2.0 x 6 I have a set for slightly cheaper than online for sale in SLC, UT.
Got a call back.
I would recommend to put everything together without a shock and measure your compressed bump length, cross reference that with shock compressed length accounting for an extended eyelets if you require it.
Hey brother.
I literally ordered them last night 😑😑😑
Sh!t.
Aight, I emailed Kartek and they put a pause on the order until I work out what I need with them (THANK YOU CHRIS!!!)
I need to start a really annoying wheel/tire thread to work out what I'm doing with this thing. That will largely dictate which coilover I will run.
I'm currently sitting on 245/75R16 and I can't stand them. I'm also lifted entirely too high which does not help.
I'm probably going to wind up with an 18-20in rim so I can get the tires I want (wide, aggressive street tires like what's on my Challenger) and need to order the coilovers appropriately so everything is right on the first shot.
I may be a little late to the party but regarding availability of that Fox shock, Kartek is top notch & my first choice.. Also questions on what shock in this series, feel free to contact Fox directly at the "Motor Sports" contact number...but I could only find their corporate number, but they may still work with you if you can get an applications motorsport engineer on the phone to consult with, or, simply add your amount of lift to the starting compressed length & add the 6.5 inches to then have the extended length.
