93 Splash in SC, V8-Swap version
Featured Build Threads
Tape measures don't always work well for swapping stuff either, sometimes the angle of the dangle varies just enough to work when a tape measure says it won't.
Dang it, Ford!!!!!
So, rumor is that to fit my 4406 t-case under the Ranger, I will need to clock (rotate) it a few degrees because it won't fit between the frame rails. A while back, i saw a clocking ring on the internet. But it was expensive. Over $200 if I recall. I figured I should be able to design one and make it or have it made for a lot less. So, i took some quick measurements, designed a ring and added 2 extra sets of bolt holes at 10 degree intervals. I thought I could have a template 3d printed that I could then use to mate the t-case to the transmission tailhousing and figure out how far to clock the t-case so it would clear the frame rail.
Well, it turns out that the bolt holes are not evenly spaced around the housing. I made my template with a nice neat even 6-hole bolt pattern. And only one hole matches up.
Back to the drawing board.
My 3d printed template. 3 nice 6-hole patterns at 10degree intervals.
Here are the actual bolt spacing distances around the circle. You can see that most of the measurements are close to the same. I'd like to hurt someone.
Well you see that pattern is very old... the offset is probably at least partially influcanced by the locating dowel and the notch for the shift rail on old t-cases like the NP-205.
This is a spacer I had cut out to hang a NP-205 on the back of a 2004 M5ODR2 that previously had a BW4406 on it:
I definitely understand that. This whole exercise centers around measuring irregularly shaped objects in irregularly shaped spaces with little to no accurate reference positions, and not knowing exactly how other irregularly shaped objects are going to fit in their portion of the irregularly shaped space.
I don't have a flat level surface to park on. The frame isn't straight and uniform. I don't know exactly where/how the engine will sit... it's all precision guesswork.
Replacement water pump just arrived. That one I had from FlowKooler looked great. They talk a great game. And, based on my knowledge of pumps, I could easily see that it would be more efficient and flow more water... IF it fit. But, after 4.5 weeks and at least 4 attempts to contact FlowKooler, I have still not received a response. So, in summary, their pump doesn't fit and their customer service is non-existent. I really have nothing good to say about the company.
Summit Racing, on the other hand, is awesome. I reached out to them on Wednesday. Filled out the return request form on their site. At the end, it asked if I wanted an exchange and what part number I wanted in exchange. I found a regular pump on their site and when I clicked on its description, a popup asked me something about price matching with another site. So, in another window, I looked up the same pump on RockAuto. Behold, it was considerably cheaper. So, I opened a chat window and explained what was going on. The tech in my chat adjusted the price, completed my return process and initiated the shipping process for the replacement pump. I checked my email and saw my RMA# with the prepaid label to print for the pump I was returning, and another email acknowledging my refund of the difference once they receive the returned pump. The whole process took way less than 30 minutes. That was all on Wednesday and the new pump just got delivered.
That's why Summit Racing gets my business.
I sure do hope I get this thing back to operational status some day.
Yeah, Summit Racing is pretty stellar. Real, old-fashioned customer service and support and crazy fast shipping. I love dealing with them.
I've yet to tackle an auto myself, pretty much my best friend is a trans tech and knows what he's doing with them so I usually hand him some beer and hang out for a bit... the dang guy can hold a conversation building most common transmissions and barely look at what he's doing, starts drilling out random holes in stuff and chucks random parts aside saying they aren't needed... my 4R70W works fantastic so I don't question it :)
Today, I got the rest of the guts out of the transmission case. This was complicated by the broken output speed sensor from yesterday. That thing was stuck really bad. While twisting and prying, yesterday, the whole concept of "gently" flew out the window and the sensor broke off even with the outside of the case. It protrudes on the inside and prevents removal of the final shell and output shaft assembly. You do NOT want this problem. Anyway, with patience and a bunch of tools, I chipped out enough of it that I could get it to slide towards the outside far enough to allow the drive parts to come out. Then I pushed the remaining sensor debris through to the inside of the housing.
After that, I 90% built a special tool to help in re-installing the accumulator piston retaining rings. Didn't feel like hooking up the welder for 2 minutes of welding.
Also drilled and tapped a hole for a magnetic drain plug on the bottom pan.
Empty case
Drain plug installation. I had welded the reinforcing pad on a few weeks ago. Just had to drill and tap it straight and square so the copper washer will seal.
This is the tool for the accumulators. It actually needs one more hole drilled. This is from an instructional video I watched. You bolt this square tube/bar to the case. Then use the center threaded rod to push the accumulator in against spring pressure. That allows you to have both hands free to remove the retaining ring from its groove. I'm modifying mine with a welded t-handle and by welding a nut on the center hole for the threaded rod. The guy in the video had to hold the nut with a wrench while he twisted the wingnut to screw in the threaded rod. He did it that way to show that anybody with a drill and a hacksaw could make the tool cheaply.
Empty case
This is the tool for the accumulators. It actually needs one more hole drilled. This is from an instructional video I watched. You bolt this square tube/bar to the case. Then use the center threaded rod to push the accumulator in against spring pressure. That allows you to have both hands free to remove the retaining ring from its groove. I'm modifying mine with a welded t-handle and by welding a nut on the center hole for the threaded rod. The guy in the video had to hold the nut with a wrench while he twisted the wingnut to screw in the threaded rod. He did it that way to show that anybody with a drill and a hacksaw could make the tool cheaply.View attachment 143829
I started building a slightly different version of that tool awhile back. I need to finish it up and test it one of these days.
I feel like I've conquered a mental hurdle that has been bothering me. The water pump was a pain in more than one way. I couldn't find anybody who sells a good set of water pump and timing cover bolts. They all need to be different lengths and some of them need threads that extend past their heads so that other things can be fastened to them with nuts. I had ordered some bolts from Dorman. But only about 3 of the bolts I ordered would work.
So, I made my own. I went to my favorite industrial hardware supplier and asked for grade 8 threaded rod. For those who don't know it, that doesn't exist. I learned that all-thread is graded differently. The closest equivalent to grade 8 is grade "B7". So, I got a 6ft stick of 5/16" B7 threaded rod and a bunch of grade 5 flange nuts. Much cheaper than McMaster-Carr and no shipping cost. It pays to find your local Indusyrial hardware supplier.
Today, put the timing civer and water pump in place with a couple temporary screws. Then used a dial caliper in "depth gauge" mode to get length measurements. Soon, I had all the studs cut. Put some goop on the gaskets, stuck it all together and torqued them appropriately. Voila!! What a reloef to have that done. I can start assembling the engine.
As I added the front end accessories, I found one stud that I need to remake about 1/2" longer to hold my idler pulley bracket and 2 that I need to trim excess threads from so they don't interfere with the serpentine belt. Now I can start to inventory the loittle detail parts that I hadn't ordered yet - t-stat & gasket, crank sensor, a couple mpre gaskets and seals...
Old water pump bolts on the left. Useless Dorman assortment on the right.
My custom hardware in place.
Good fit.
Most of the front end stuff hung.
I think the cast iron 289 manifolds were a good choice.
I like how that manifold fits up close and tight.
Oh, yeah. Shout out to Carson's Nut, Bolt & Tool.
I like that idea a lot, but if I do it I will use stainless rod.
Oh I am going there!
Hot damn, there's one in Anderson!
Careful. They sell tools. Good quality name brand tools for contractors.
They don't sell "automptive-spe ufic" hardware. If you need that, come to Greenville and visit AAA Fasteners.
I used stainless for my build. Somewhere I have a list of what I used but my life is currently chaos.
Event Coverage
Featured Ranger Based Vehicle
