Aces Killshot Fusion EFI Swap
Fuel pressure is set, dizzy is locked down, plug wires are on and hooked up... start the countdown clock.
They want over 42psi, I went 50.
Plan tomorrow after work (I get off at 11) is to winch it outside, put the battery charger on it and clean up the garage and put tools away and if I can hold myself back work on the fan relays.
Then when I can't take it anymore we will see if it will do anything.
I know I'm a little late to the discussion, but I've found oddball half size wires is common in cheap applications like basic car audio. It's also usually copper clad aluminum. IE: CRAP.
For stripping I use a pair of Plastic Process Equipment gate cutters. Usually the 7" sometimes the 6". The blades are so soft it won't cut much wire before it it's a serrated edge. LOL. I've learned to feel the difference between the insulation and the wire.
Your link is asking me to download a pdf. Any way you can screenshot the info and post it?
It looks like a catalog page for a bunch of dikes and end nippers. I don't see anything on it thst I would use for wrie stripping except in an emergency.
I just ripped out my old fuel line. I’m probably going to end up cleaning the old pump and use it for fluid fills muhaha
  • Aces Killshot Fusion EFI Swap
I beat it home after work and threw the charger on the truck while I put tools away.
It was daunting but I did get brave enough to rip the battery charger off after half an hour and give it a whirl.
Nothing, Just cranky cranky. I have gas when the computer turns on. Kind of like a accellerator pump shot to get things started, injectors don't fire until it sees RPM signal
I get out my spark tester... sure enough no fire.
So I grab my spare coil from yesteryear and pop it in:
I had tach signal on the computer so I knew the dizzy was talking (they will do something similar if they don't have tach signal.
Just start and die start and die. Starts quick though.
I start poking around and notice my fuel pressure gauge is basically nil. I jump it to let it run and it won't prime.
It was super low on fuel when I dropped the tank (intentionally) and I dumped a little more in it but its crammed against the wall and it is hard to get gas can in there without making a huge mess.
So I took a gamble and made it drag its sorry self out of the garage.
Dumped 4gal of gas in it, system primes immediately. It fired right off, kinda hunted for a bit and settled in to a nice idle.
How it starts:
I didn't have the fans hooked up so I didn't run it super long, temp got up to 190, dash gauge even works. Sender for Autometer gauge had a drip.
So yeah, I am pretty stoked! :yahoo:
It does have tip in bog which is pretty well documented on how to deal with. It also kind of hunts a bit. Like I let the clutch out and the IAC opens to keep the idle where it was, Push the clutch in and the idle climbs until the IAC pulls it back down.
But its still a baby, it hasn't done any learning at all yet either.
It is downright AMAZING how smooth it idles as well. I thought it idled fine before but everything down to the exhaust note is totally different.
Anyway, tongiht I circled back and I think I fixed the coolant leak by throwing more fittings and several different more connections to leak. I did put the efan box back together and plugged it in and put a lot of the new wiring in loom. And I also deleted this tumor of wire.
How it starts:
It is downright AMAZING how smooth it idles as well. I thought it idled fine before but everything down the exhaust note is totally different.
im so hyped for you, this is the 2.9L you have right? Once it does the self learn you can mess with the tuning and get it all dialed in, relearn TPS, adjust fuel, etc.. that thing is coming along nicely!
:annoyed:
:shok:
:fie:
:buttkick:
:nono:
:ban:
It is a 302 cubic inch 5.0 liter Ford small block V8
He's doing this on a 302/5.0l
(Oops. We hit send simultaneously)
I got the tip in bog tuned out! :yahoo:
It goes way rich at part throttle under a load, falls on its face and sounds like it is trying to shoot flames/gunfire out of somewhere though.
With the tip in bog gone I need to delve more into actually tuning the rest of it.
It is still running richer than Oprah...
Fans are MIA... but I remembered I can bypass all that to make them run so I did that.
Fan1 is set to come on at 195, it never did so I need to check into that. Fan2 is set for 199 for testing and it did come on... which triggers my CEL (also note my factory gauge is now working)
That makes me wonder , if i can wire up a CEL tied from the aces ECU, not that id really need it lol.
Send us some videos of that mug running bro. ✌️
I was playing with the fuel table and shut the truck off for a bit. Went to restart and it started and died right away... and I lost everything. Like everything down to the dome light. All my added on stuff runs off a relay ran by the key power that originally went to the factory coil so without the original truck harness functioning I have absolutely nothing.
So I close out the aces program and pull up my scanned EVTM, eventually come across this:
I cut it out and jumped it and I got lights back.
I just deleted the connector to get the thing back inside before the rain got worse.
So yeah, most of the night was spent on a wire chase.
