3.0 Timing Help
eloyc
Forum Member
Midland
TX - USA
Vehicle
Drive
Got everything back together after a headgasket job and replacing mucho parts. I have crank but no start and I'm quite sure it's the timing/distributor/plugwire setup. I think I'm doing it right but probably not, I probably got it wrong somewhere, if anyone could help out with how to set it back to factory timing, thank you. Even my dog looked at it like, " yeah you aint got that set up right"🙏🙇‍♂️
  • 3.0 Timing Help
  • 3.0 Timing Help
Have you read through this tech article?
It's been a while since I did it. But, I believe base timing is set with the Spout jumper removed. On my 93, the Spout was near the ignition module up near the driver side headlight on the radiator support.
I've tried everything I could think of, so close yet so far away. Just keep getting crank no start
I once had a problem like yours after having the engine out. Ended up it was a connector where the orange weather proofing was holding the connectors apart just enough to cause no contact. A little spray lube corrected that. It took me several months to figure it out as I had taped up all connectors so I "knew" they were good....
I'll give all my connectors and check, also thinking it might be the ICM
Connections are good, changed my icm/tfi and that did nothing, plugged in code reader KOEO and just got 111, 10 which should indicate all good. The timing I'm using is 0° at top dead center, distributor pointing at number 1 and firing sequence 1-4-2-5-3-6 as per manual. I checked my fuel rail pressure tab and pressed down and got fuel flowing out, air shouldn't be a problem and when connecting a spark tester I do believe I'm getting spark. :\
So, have you tried 10deg BTDC like the tech article recommends?
Timing should be 10°btdc
I have and still nothing, i can try again thought. my question about that is when changing over to 10° btdc i saw that some people only mess with the cap and other completely rotate the harmonic balancer and then reinstall the distributor to be pointing at 1. Which is it?
My understanding is that the timing belt/chain and sprockets are installed with the marks all lined up while cylinder 1 is at tdc. Then the distributor or cam position sensor is aligned so that timing is at the specified point, in this case, 10deg btdc. Then run the engune and fine tune it.
Just to verify, this would be the correct 10° mark? Also I did a compression test got about 125 on each cylinder
  • 3.0 Timing Help
Also, thank you everyone chiming in i really appreciate it. 🙇‍♂️
This is my distributor and degree on harmonic balancer at 10 btdc
  • 3.0 Timing Help
Just to make sure...
#1 cylinder on ford 3.0L is the one farthest to the front passenger side. Cylinders are number 1 to 3 going front to back on passenger side. Drivers side are number 4 thru 6 front to back.
Normally I like to have the #1 sparkplug wire on the cap oriented pointing to the # 1 cylinder on the engines I've worked on. Not sure about the 3.0L.
Your cap wiring looks correct order. And it doesn't really matter where the #1 cap wire is as long as there is enough movement to put the timing at 10°.
Any chance you set #1 to TDC exhaust? Regardless you should get some pops and bangs. You sure the injectors are firing? If you pull a plug after trying to start it, is it wet with gas? Have you tried spraying some flammable liquid into the throttle body to see if you get anything then?
