Another noise!
N/A
PE - CAN
Other
1968 Charger, 2005 Camry
Vehicle
Drive
Stock
none
Heya folks, back with more noises that may or may not be worrisome.
It's making a high tone echo-y rattle from passengers side, sort of in the middle of the wheel-well, it goes away mostly after a 30 minute drive @ highway speeds. I assume this would be the time to change that tensioner, I'm going to go with Melling and I'll see how it goes.
Just wondering if other people have had a similar noise & and it wasn't the tensioner.
It's not the whirring noise that drowns everything out, it's that sort of rhythmic thumping that echoes under the cab; not the exhaust as I had that done recently.
Sounds like an exhaust leak at a manifold somewhere. Once it gets hot and expands, it's sealing back up.
That sounds like a starter running to me. Phone audio is weird...
Starter running, would you care to expand? I'm confused.
Here's a clearer video of noise, it still persists even after replacing the tensioner.
Sounded like the starter was still engaged. IE: starter running after the engine fired.
The second video is much clearer to me. I agree sounds like a minor exhaust leak.
