The Saga of Truck Norris
Featured Build Threads
Rebuilding the M5OD isn't rocket surgery, if it just needs a refresh kits are only like $175ish on amazon/ebay last I looked without synchros. but being in an apartment I get it...
Yeah, it sucks for non-rocket-surgeries. 🙁
It makes my eyes water just knowing that the cost of everything is so high that I'm making a bit of the money I promised myself I'd make when I got to this age, but instead of buying a house I'll be lucky to rent something that isn't bolted to my neighbor.
Lots of reasons for rebuilding over new purchases, but my favorite is that it's  mine. Nobody's trying to shut my car off, or charge me a monthly subscription for heated seats, or use my vehicle's radio to build telemetry and user data for data brokers purchased from GM, Toyota, even the DMV in some states...
No thank you. I'll rebuild until I can't anymore, then buy myself a neon green rain suit and a Chinese motor scooter.
Don’t get me started on it all, I’m liable to climb up on my soapbox and start ranting and this forum isn’t the place for that discussion because it gets a little political although I will say that both sides are part of the problem. I’ll leave it at that.
I think when the day comes that I can’t rebuild my rigs anymore, a horse may be the practical transportation :icon_rofl:
This just in, the US Government has partnered with Palantir to mandate horse trackers, due to the long legs of horses being hazardous for children.
@Rick W, here are some of the pics I promised!
And a close-up:
This weekend is going to be dedicated to the rear suspension. I got a notification that I'd received a refund for one of the oops LCA's. When the other one hits, I'm going to order the correct set of coil spring LCA's.
On this episode of Redneck Garage...
All my jacks are too 🦆ing small.
...it starts. Good luck, bud.
Jacks? Or jack stands? Either way some plywood or stacked 2x... will help. Should use that on asphalt anyway as I've seen them sink in..
Yeah, those 3 ton jack stands only work under the axle or I beams, 6 ton are almost too short to get to the frame in front of the beams or behind the axle... get yourself some scrap 1' chunks of 2x4 to put under them to gain some height.
They, uh, ran out of scraps...
  • The Saga of Truck Norris
Trailer hitch installed after the spring, that's nice... Looks like the upper bracket is coming off...
It did take me all day to figure out how to install the damn thing. Yeah, it was easy, but aligning everything by feel was interesting. You know what they say, the first time takes the longest! Next one tomorrow.
If the other side is the same just take the front leaf spring bolt out first then you can rotate the shackle forward to get the bolt out... It looks like someone before you changed the shackle brackets, they were riveted from the factory.
Event Coverage
Featured Ranger Based Vehicle
